Hi,
I tried to make a SVCD from an AVI file but I had to extract the audio first through Virtual Dub. Then in TMPGEnc I loaded the SVCD template and loaded the AVI file and the WAV that I had extracted. After encoding when I play the file the audio keeps breaking up.
Any Ideas?
Mr Shibby
Its possible that the source audio is at 48khz sample rate and TmpGenc is downsampling this to 44.1khz to meet SVCD requirements. Unfortunatley TmpGenc does not seem to do a very good job of this. Therefore it is reccomended that you convert the audio sample rate outside of TmpGenc. You can do this when you save the audio file from virtualdub, and it does a better job than TmpGenc, though dedicated audio tools are better still.
Thanks Bugster.
I have virtualdub open now but I'm not sure where I can change the rate?
Thanks -
under audio->full processing modeOriginally Posted by Mr Shibby
file-> save wav
use this wave in BeSweet GUI and using this, you can downsample to 44.1K, and encode to .mp2 at whichever bitrate you choose(192,224...)
DESPERATE subtitle help -- trouble merging or making another channel
By andrewzors in forum SubtitleReplies: 14Last Post: 17th Jun 2011, 17:09 -
FLIP camcorder - having trouble making movie after uploading video
By jellybean3009 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Aug 2010, 12:02 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 05:57 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 12:07 -
TMPGenc Xpress FPS trouble
By shorto in forum Video ConversionReplies: 0Last Post: 6th Sep 2007, 18:59
