Hi
i have re-download eac 1.3 and lame_enc.dll from rarewares LAME 3.99.5 32bit Bundle compiled with Intel Compiler 14.0.3.
lame_enc.dll hash
MD5: AB70669CA143E7CC72C94B07C5335D24
well i did a clean install of eac 1.3 and i copied lame_enc.dll in the root folder c:\Program Files (x86)\Exact Audio Copy\
when i run the first time eac i can see it and i can use it
at the second time
what's wrong? can you please test it?
and i know i can use the command line ,but it's pretty nice hard to configure for me
is there a colletion of encoders profiles (like lame,flac,qaak and other encoder) that i can download and import on my eac ?
thanks
I haven't played with this settings for a long time, but I'm pretty sure the Waveform encoding with lame_enc.dll doesn't create mp3 files; it creates wav files with mp3 encoding or, put in a different way, mp3 streams in a wav container. Some media players may not support this format.
"The greatest trick the Devil ever pulled was convincing the world he didn't exist." -
Isn't it supposed to be configured under the External Compression tab?
http://wiki.hydrogenaud.io/index.php?title=EAC_Compression_Options#External_compression
I haven't use EAC in years but I kind of remember setting up encoders was unnecessarily hard. There's command line examples for LAME here:
http://wiki.hydrogenaud.io/index.php?title=EAC_and_LameLast edited by hello_hello; 26th Jun 2017 at 05:32.
If you decide to use the command line, you can (Let's see if I can get this right
Select 'Compression Options' from 'EAC' menu.
Click 'External Compression' tab.
1. Check 'Use external program for compression'
2. Change 'Parameter passing scheme' to 'User Defined Encoder'
3. Set file extension to .mp3
4. Click 'Browse' and locate your file 'lame.exe'. You could just copy/paste it into c:\Program Files (x86)\Exact Audio Copy, in which case you'd just browse to that location, select lame.exe, click 'Open'
5. In 'Additional command line options', for Preset:Standard enter: -V 2 %source% %dest%
6. Check 'Delete WAV after compression', unless you want to save the WAV files too
7. Check 'Check for external compression return code'
8. If you want EAC to add ID3 tags check 'Add ID3 tag'
-In which case you probably want to configure the 'ID3 Tag' section in 'Compression Options'
-Also, the 'EAC'-->'EAC Options'-->'Directories' tab, and the 'Filename' tab for where you want your mp3's placed and how you want them named...Maybe also 'Character Replacements' if you want EAC to replace certain characters in your tags/files with others
-If you also want EAC to create an m3u playlist for each disc you can check that in 'Tools'
9. If you want lame.exe to write the ID3 tags instead of EAC, you uncheck 'Add ID3 tag'in 'Compression Options' and configure the 'Additional command line options' with the instructions also included on the 1st page hello_hello linked toPut NBC's Ed on Blu-ray! -
You're welcome.
BTW, rarewares also has flac.exe encoders etc.Put NBC's Ed on Blu-ray! -
hi
i know , it's the only site i know , and i get the enocder from rarewares
thanks because i don't know but my antivirus avira barks when i try to download cdex or audiograbber
and the only alfternative is fre:ac
thanks! -
Have you tried CUETools? It's advertised as an open source alternative to EAC, and configuring it probably has a marginally lower degree of difficulty. CUERipper comes bundled with CUETools.
I use foobar2000 for ripping myself. It has secure ripping modes.
http://cue.tools/wiki/Main_Page
http://www.foobar2000.org/
The patents relating to MP3 expired recently so I imagine most software that uses LAME for encoding will bundle it in the future. The foobar2000 encoder pack now includes it. http://www.foobar2000.org/encoderpack
If you're downloading cdex or audiograbber from a trusted source, you probably should ignore your antivirus program. I stopped using one years ago because having to make decisions for it due to false positives seemed to defeat it's purpose.
MSVCP60.dll MSVCRT.dll MFC42.dll: wich of this dll's do video deinterlace?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2016, 11:40 -
EAC - Does v1.1 Support Local FreeDB Database
By Jerry22 in forum AudioReplies: 0Last Post: 11th May 2016, 15:19 -
eac HD audio FPS change
By asiafan in forum AudioReplies: 4Last Post: 29th Oct 2015, 15:28 -
EAC and ghost track
By Instant Martian in forum AudioReplies: 8Last Post: 3rd Aug 2014, 09:31 -
TMPGlib.dll TMPGlibP3.dll TMPGlibP4.dll
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2014, 11:02
