Hi all,
I've captured some movies with my Hauppauge PVR card.
Now I have some VCD files, which are to big for one CD (1150kbs, VCD, 25frames, PAL).
does anyone have any idea how I can split the VCD file to write it on 2 cd's, to wach it on my stand alone player? (the player can read vcd, svcd etc... toshiba 210e)
Can I prevent this probs with creating 2 files while I capture the movie? If yes, where are the settings and which capture tool I schoul use for that?
Thanks for your help.
Cheers,
BenInsula
use tempengc. once you open the Tempengc on the file menu got to MPeg tools and select the Merge and cut tab. then add the clip you want to cut using the add button. then select the clib by clicking on it and press edit and set the start and end point and set a out put location and file name and press run. you will have the cut clip
Use "MPEGtool" for VCD's. This is a freeware program and it's quite fast. Another option is "TMPGenc" . you can cut VCD's And SVCD's, but it is quite slow.
Thanks for the hint, but if I use Tmpgenc, the sound is lost...
I tryed to cut a movie into two parts. the first part, there are no problems and at the second part,the audio is lost after about 40 minutes.
Any ideas what to do?
Thanks.
BenInsula -
Why not try vcdcutter for cutting vcd's? It's fast+easy! You'll find it on the tools page of this site.
Thanks, but after installing and registering VCDCutter I was only able to cut the first 2 minutes from thed mpeg.
Are there any good working tools to fit the recorded mpeg onto two CDs?
Thanks BenInsula
WMV Cutting
By ajitpals in forum Video ConversionReplies: 4Last Post: 2nd May 2010, 05:13 -
[FR] Cutting TS Help Me Please
By KERNEL32 in forum EditingReplies: 5Last Post: 26th Feb 2010, 14:38 -
cutting mkv
By tonyburns in forum EditingReplies: 2Last Post: 26th Apr 2008, 13:04 -
Movica not cutting where I want it to
By ThePMonkey in forum EditingReplies: 10Last Post: 29th Aug 2007, 23:42 -
Cutting Out
By OG24 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 19:55
