Page 2 of 2
FirstFirst 1 2
Results 31 to 60 of 60
  1. Content encrypted.
  2. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Originally Posted by kshycho View Post
    What program can you get the link and download it for. I think this is mpd.
    https://www.axn.pl/programy/swat/videos/swat-101
    I can't even get this thing to play,all i get is a black screen with 3 cubes "loading"
  3. There is a problem on this page with the movie display. For me on the latest Firefox works correctly, and on the old version 56 no longer.
    I was able to download the file in mp4 via Video DownloadHelper, but no image. It seems to me that the AXN.PL website has changed the player.
    Mar 2019
    Germany
    streamlink can download it. Here is the mediainfo:
    General
    Complete name                            : test.ts
    Format                                   : MPEG-TS
    File size                                : 686 MiB
    Duration                                 : 42 min 48 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 2 239 kb/s
    Video
    Menu ID                                  : 1 (0x1)
    Format profile                           : High@L4
    Format settings                          : 2 Ref Frames
    Format settings, CABAC                   : No
    Format settings, RefFrames               : 2 frames
    Format settings, GOP                     : M=1, N=60
    Codec ID                                 : 27
    Duration                                 : 42 min 49 s
    Bit rate mode                            : Constant
    Nominal bit rate                         : 2 000 kb/s
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate                               : 25.000 FPS
    Standard                                 : PAL
    Bits/(Pixel*Frame)                       : 0.087
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Menu ID                                  : 1 (0x1)
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Format version                           : Version 4
    Muxing mode                              : ADTS
    Codec ID                                 : 15-2
    Bit rate mode                            : Variable
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Menu
    Menu ID                                  : 1 (0x1)
    List                                     : 256 (0x100) (AVC) / 257 (0x101) (AAC)
    Service name                             : Service01
    Service provider                         : FFmpeg
    Service type                             : digital television
    [Attachment 49237 - Click to enlarge]
  5. I used The Stream Detector to get the link.
    C:\111>streamlink --http-header "User-Agent=Mozilla/5.0 (Windows NT 6.1; Win64;
    x64; rv:67.0) Gecko/20100101 Firefox/67.0" --http-header "Referer=https://player
    .sdpg.tv/?config=https%3A%2F%2Fplayer.sdpg.tv%2Fplayerconf%2Fconfig%2F2001%2Femb
    ed-config-2001-6-www_axn_pl-GF9KS2PXA.json&debug=false&lang=null&player_mso=null
    &parent_domain=&player_mediaid=20013931&player_muted=false&player_controls=true&
    player_autoplay=false&player_captions=false&player_captions_language=null&player
    _captions_format_font=ambleregular&player_captions_format_font_color=ffffff&play
    er_captions_format_font_size=medium&player_captions_format_font_opacity=100&play
    er_captions_format_font_style=uniformEdges&player_captions_format_background_col
    or=ffffff&player_captions_format_background_opacity=0&player_audio_language=null
    &geoCode=undefined" -o "test.ts" "https://dashwvsdpgtv-a.akamaihd.net/1A380P/1/a/mx/
    v62ln_Widevine_Dash_playlist.mpd?hdnts=exp=1559387079~acl=/1A380P/1/a/mx/*~hmac=
    086054c23df3ee4414018480d73e8e962a1603182a2a902d82cec83fae2e34a6" best
    [cli][info] Found matching plugin dash for URL https://dashwvsdpgtv-a.akamaihd.n
    et/1A380P/1/a/mx/v62ln_Widevine_Dash_playlist.mpd?hdnts=exp=1559387079~acl=/1A38
    0P/1/a/mx/*~hmac=086054c23df3ee4414018480d73e8e962a1603182a2a902d82cec83fae2e34a
    6
    [cli][info] Available streams: 288p (worst), 360p, 432p, 480p, 720p (best)
    [cli][info] Opening stream: 720p (dash)
    [stream.ffmpegmux][error] Pipe copy aborted: \\.\pipe\ffmpeg-3916-178
    Unfortunately, streamlink does not download the file.
  6. v62ln_Widevine_Dash_playlist.mpd
  7. Hi,
    is it possible to download the video behind this mpd file:
    https://vodnowusoawsdash-a.akamaihd.net/proxy195/manifest/tvnow/1650884-2.ism/.mpd?fil...in=0&vend=1408
    I tried youtube dl but got the message "no video formats found (please report this issue on ..."
    Also tried ismdownloadAVC1 but there I got the message "Manifest root element must be <SmoothStreamingMedia>") (the root element from the mpd above is obviously mpd)
  8. Originally Posted by LZAA View Post
    Drm.
    I am not into this kind of stuff. But if a media is DRM protected, does it mean that its not possible to play it (if you dont have the corresponding key) or is it just not "legal"?
    Regards
  9. Originally Posted by himzo_polovina View Post
    The former.
  10. Content encrypted.
    Aug 2019
    croatia
    I got this mpd: https://cdn1.oiv.hr/hrtnpvrorigin/467193028.smil/manifest.mpd
    which I couldn't read with Youtube-dl neither Video DownoadHelper
    Any idea?
  12. Originally Posted by zkalinic View Post
    Any idea?
    url page video
    Aug 2019
    croatia
    Any idea?
    url page video
    https://hrti.hrt.hr/live/tv
  14. Anonymous84
    Guest
  15. Anonymous84
    Guest
  16. VPN which country?
  17. Anonymous84
    Guest
  18. Hi folks,
    I would love some directions from you to download an MPD video.
    I've tried the various options described above (youtube dl, ffmepg, streamlink) and didn't get much luck.
    Here's my MPD file:
    >> https://benshi-cdn.vodfactory.com/videos/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_...downscaled.mpd
    Would anyone have a tip on best way to achieve this?
    Thanks a ton
    Greg
  19. The MPD URL doesn't contain all the information needed to download the video. You must supply the URL of the web page that plays the video. That's what LZAA is asking for.
  20. Code:
    youtube-dl.exe -F "https://benshi-cdn.vodfactory.com/videos/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_feature_downscaled/dash/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_feature_downscaled.mpd"
    [generic] B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_feature_downscaled: Requesting header
    WARNING: Falling back on generic information extractor.
    [generic] B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_feature_downscaled: Downloading webpage
    [generic] B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_feature_downscaled: Extracting information
    [info] Available formats for B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_feature_downscaled:
    format code    extension  resolution note
    audio_en_mp4a  m4a        audio only [en] DASH audio  204k , m4a_dash container, mp4a.40.2 (44100Hz)
    video_avc1_1   mp4        1024x576   DASH video 1059k , mp4_dash container, avc1.640028, 25fps, video only
    video_avc1_2   mp4        1024x576   DASH video 1966k , mp4_dash container, avc1.640028, 25fps, video only
    video_avc1_3   mp4        1024x576   DASH video 3181k , mp4_dash container, avc1.640028, 25fps, video only
    video_avc1_4   mp4        1024x576   DASH video 4114k , mp4_dash container, avc1.640028, 25fps, video only (best)
    youtube-dl.exe -f bestvideo "https://benshi-cdn.vodfactory.com/videos/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_feature_downscaled/dash/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_feature_downscaled.mpd" -o video.mp4
    [dashsegments] Total fragments: 211
    [download] Destination: video.mp4
    [download]   1.7% of ~82.79MiB at 756.54KiB/s ETA 02:56]
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/avc1/mp41/iso5/iso6)
    File size                                : 101 MiB
    Duration                                 : 6 min 59 s
    Overall bit rate                         : 2 018 kb/s
    Video
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, Reference frames        : 4 frames
    Codec ID                                 : encv / avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 2 000 kb/s
    Width                                    : 1 024 pixels
    Height                                   : 576 pixels
    Frame rate mode                          : Constant
    Bits/(Pixel*Frame)                       : 0.136
    Stream size                              : 101 MiB (100%)
    Writing library                          : x264 core 152 r2854 e9a5903
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language                                 : English
    Encryption                               : Encrypted
    Codec configuration box                  : avcC
  21. Thank you both for your prompt help!
    @slimozis that's insane. When I copy/paste that first line it returns an error for me.
    This command
    youtube-dl.exe -f bestvideo "https://benshi-cdn.vodfactory.com/videos/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_featu re_downscaled/dash/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_featu re_downscaled.mpd" -o video.mp4
    Gives me this outcome
    [generic] B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_featu re_downscaled: Requesting header
    [generic] B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_featu re_downscaled: Downloading webpage
    [generic] B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_featu re_downscaled: Extracting information
    ERROR: No video formats found; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
    Obviously I'm running the latest version of youtube-dl, freshly updated from their official site.
    Here's the verbose output
    [debug] System config: []
    [debug] User config: []
    [debug] Custom config: []
    [debug] Command-line args: ['-f', 'bestvideo', 'https://benshi-cdn.vodfactory.com/videos/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_featu re_downscaled/dash/B001270ShaunLeMoutonS01E01Partiedefoot_hd_vf_featu re_downscaled.mpd', '-o', 'video.mp4', '--verbose']
    [debug] Encodings: locale cp1252, fs mbcs, out cp850, pref cp1252
    [debug] youtube-dl version 2020.05.29
    [debug] Python version 3.4.4 (CPython) - Windows-10-10.0.18362
    [debug] exe versions: none
    [debug] Proxy map: {}
    File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\ytdl-org\tmpxtvjzx45\build\youtube_dl\YoutubeDL.py", line 797, in extract_info
    File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\ytdl-org\tmpxtvjzx45\build\youtube_dl\extractor\common. py", line 530, in extract
    File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\ytdl-org\tmpxtvjzx45\build\youtube_dl\extractor\generic .py", line 2400, in _real_extract
    File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\ytdl-org\tmpxtvjzx45\build\youtube_dl\extractor\common. py", line 1350, in _sort_formats
    youtube_dl.utils.ExtractorError: No video formats found; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
    Am I missing something ?
    Greg
  22. hi all
    trying this one :
    https://astrogo.astro.com.my/hubHome/series/astro.com.my_47_PACK0000000000217256~vod
    stream is:
    youtube-dl --no-part --restrict-filenames "https://vodejitp-asset-playback.astro.com.my/dash/vode/dcf0695f-a578-50d4-a31e-338abfb5d419/default_ott.mpd"
    but returns no unknown mime type.
    i have tried ffmpeg but not working too.
    hopefully someone can help
  23. There is a script that I came along in Github, it is called Drm-Dash-stream-downloader. If you have the key of the video, you can use it to retrieve the drm free content. It automates the process of downloading the manifest , parsing it, downloading and finally decrypting the content. It uses FFmpeg for decrypting AES-128 encryption and Bento4 for other cipher suites.
