Hi all
I've captured a VHS (PAL) movie using my ATI AIW 128 Pro to MPEG-1 file.
Then I imported the file into Adobe Premiere and exported the audio track in WAV format.
The resulting WAV file was identical in length to the mpeg file.
The problem is regardless of the tools I use, I always end up having audio sync problem in the encoded file.
I have tried the following:
- Virtualdub's frameserving to Panasonic MPEG-1 encoder
- Encoding the captured mpeg file and the WAV files in Panasonic MPEG-1 encoder.
- Encoding with Premiere.
I have read -almost- all related posts on all forums and all guides, and tried every suggested solution but with no success.
My system details are as follows:
PIII 667
Win98 SE
512 MB RAM
20GB HDD ATA 66
ATI AIW 128 Pro (32MB)
Am I missing anything?
Mike
If you captured with your AIW, was that using ATI MMC? If so, what version of MMC?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
