My guess is you made the AVI file using the Bob Doubler filter in VirtualDub. Then opened the AVI using that same instance of VirtualDub. The program doesn't clear out all the filters when you open a new file -- meaning the Bob Doubler filter was still active. So you were bob doubling twice, hence the 4:6 repeat pattern.
No, if the percentage is anything less than 100 it's a mix of hard and soft telecine. For example, 99 percent soft telecine, 1 percent hard telecine. But when there is only a little hard telecine you can often get away with ignoring it, treating the whole video as soft telecine, without getting audio/video sync problems, or being left with a lot of interlace comb artifacts.
Results 31 to 31 of 31
Blu-ray frame rate of 48 & 24?
By clashradio in forum EditingReplies: 11Last Post: 1st Apr 2017, 19:46 -
Frame Blend Frame Rate Conversion with Scene Change Detection
By ndjamena in forum RestorationReplies: 7Last Post: 3rd Nov 2015, 09:26 -
How to find out frame exposure time in a variable frame rate .mov file...
By bananas100 in forum EditingReplies: 5Last Post: 24th Oct 2014, 19:18 -
Telecine and irregular dupe mix - restore original frame rate ?
By LMotlow in forum RestorationReplies: 16Last Post: 14th Jul 2014, 20:09 -
MediaInfo: Frame Rate vs Original Frame Rate
By adalect in forum Video ConversionReplies: 1Last Post: 19th Aug 2012, 17:44
