Hi, I take it to copy a VCD it is pretty easy?
Just use Nero or Clone to copy it, like copying a music cd?
Thanks.....
I have been copying vcds to cd-r and they have been playing okay on my dvd player that definatley supports vcds. However, sometimes when I make these copies, they don't play although they are apparently burnign something on the disk. what is the problem and can you please help me? If it helps, I am making copies of copies.
Thanks,
bjbj -
Generally, there should be no problem copying a VCD to another CDR, assuming your drive supports disc at once mode. Problems like this are usually in my experience due to either a) burning at too high a speed, in which case step down a little, or b) bad media, in which case try branded discs. Unbranded cheapies work fine on my machine, but not on a few of my friends, so I need to use branded discs for copies for them. I also need to burn at 8x or slower for their players to read them all of the time rather than just when they feel like it :-)
Tachyon. -
Its probably the media you're using...
What kind are you using?
The Terapin VCD Recorder
www.VCD-TRADING.com
Check it out and Start Trading Today! -
I have been using imation 700mb 80min. cd-r. Since the question, I have slowed the speed down to 8x, and It seems to be working okay now. However, what is the problem when I encounter errors while reading the cd? Sometimes it aborts on its own, and sometimes it trries to continue. But I am wondering what these errors are, and how I can get them out of there! I noticed that most of the time the time the errors occur correspond with the messed up lttle glitches in the video. What can I do about it?
Peace,
bjbj
copying streaming
By ruthann in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2011, 12:14 -
dvd copying
By ruthann in forum DVD RippingReplies: 9Last Post: 26th May 2011, 18:57 -
copying
By merc68 in forum DVD RippingReplies: 13Last Post: 7th Nov 2009, 18:26 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
copying????
By bamf321123 in forum DVD RippingReplies: 1Last Post: 23rd Jun 2007, 07:39
