Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Jun 2017
    JAPAN/TOKYO
    How to fix to Mpeg2-TS bitrate.
    I want to create the MPEG2-TS(Static Bitrate) & specify PID.
    I can specify PID by FFMPEG , but it cannot create MPEG2-TS(Static Bitrate).
    Therefore,
    Step 1: I used Adobe Media Encoder to create CBR file.(This file is really static bitrate).
    Step 2: I used FFMPEG to the CBR file into specify PID(command: -vcodec copy -acodec copy).
    But It cannot static!!
    Anyone know how to fix the bitrate by FFMPEG??
    //Except [-b:v 2500k -minrate 2500k -maxrate 2500k] it is only way to x264.
  2. How are you measuring the bitrate? or determining if it's static (or not) over time ?
    Did you try specifying -muxrate ? Or else try tsmuxer CBR (I think it inserts padding)
    Jun 2017
    JAPAN/TOKYO
    Thanks a lot!! -muxrate can static messuring bitrate.
    But When I use -muxrate code, The error of below came out.
    [mpegts @ 00000000005827a0] dts < pcr, TS is invalid
    Do you know happen to know this one?
    My all code is below.
    ffmpeg -i input.ts ^
    -vcodec copy -acodec copy ^
    -muxrate 14500k ^
    -c:v copy -c:a copy ^
    -mpegts_transport_stream_id 0xBC ^
    -mpegts_service_id 0x10 ^
    -mpegts_pmt_start_pid 0x0050 ^
    -streamid 0:0x00ff ^
    -streamid 1:0x0100 ^
    output.ts
