Hi
I dunno whether this was the right forum, but it was as close as i could find.
I need help on the playback of vcds on my playstation.
I have a vcd adapter for the playstation and when i play vcds , its usually a bit strechted out horizontally so i cant see subtitles etc, but when i press the start button on the controller, it usually fixes it because it turns on PVC(i think thats wot it is, it allows forwarding, pausing etc).
Here's the problem, i got this Karaoke vcd, and the words of the second line on the bottom are hidden because the screen is streched again, only this time, pressing start to turn on PVC ISNT WORKING!!!! Karaoke just isnt karaoke without the words!!!!! I've tried playing the vcd on the comp n it works fine, i can see the words, so i dont think its the disc (as in its not faulty).
Can someone PLLLLLLLLLLLLZZZZZZZ help me?!?!?!!
thank you very very much
Lazerin
Results 1 to 1 of 1
DXVA not playing??????plz help
By ansonjoy in forum Software PlayingReplies: 7Last Post: 9th Dec 2011, 08:35 -
Help PLZ! subtitle problem.
By Ajimal in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 22:25 -
Help with Mac The Ripper Plz!!!
By ILoveMovies12345 in forum MacReplies: 2Last Post: 24th Apr 2009, 11:08 -
How to playback BluRay plz ?
By Cov(enant) in forum Blu-ray RippingReplies: 2Last Post: 16th Sep 2008, 17:44 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12
