Although I bought my Pioneer DV-270-s some years ago, I have recently started making my own discs from digital and analogue sources. However, when I try to play these on my machine, an error 'No disc' (or similar) appears. Is there anything I can do to have the player play these ??
1) It's 13 years old.
2) Are you "authoring" actual DVDs or just burning files to a disc(drag and drop)?
https://www.videohelp.com/glossary?A#Author -
You can look at the Media Player guide (top of this page) and you'll find that your player should play both DVD+R and DVD-R (i.e., disc you record yourself).
Pioneer DV-270
However, hech54 has nailed it: you have to "author" a DVD so that the video will play on a set-top DVD player, like your Pioneer model. You can tell if a DVD is authored because it will have two, and only two folders: VIDEO_TS and AUDIO_TS. The AUDIO_TS folder will be empty, but the VIDEO_TS will have a bunch of files with the extension VOB and IFO. If your disc doesn't have these files, then you did not make it using DVD Authoring software, and your video will not play.
Some newer DVD players can play DVDs that simply have MP3 files (for audio) or MP4 files (for video), as well as files of other types. However, I don't think that is true of your model.Last edited by johnmeyer; 21st Jun 2017 at 10:18. Reason: added link
Thanks for your responses. I have been using Pinnacle Studio (10.5) to edit my videos and then burn them to the dvd which plays OK on my laptop. How do I find how to do 'authoring' ??
Please re-read my earlier post: if the disc created with Pinnacle Studio has those two folders, and if the VIDEO_TS folder contains VOB and IFO files, then you have authored the DVD, and the problem lies elsewhere. However, if you don't have those two folders and you don't have VOB and IFO files, then all you did was render to a single video file. This will play on your computer, but it won't play in most DVD players, and certainly not in the one you own.
The good news is the Pinnacle Studio can author a DVD. You just have to select the correct options during the third of the three steps the software provides in its UI.Last edited by johnmeyer; 4th Jul 2017 at 10:40. Reason: typo ("correction" should have been "correct")
Could be possible that your dvd player Lazer may be dying.
Does it read store bought pressed disc's ok ?? -
Many thanks for everyone's assistance. It seems that I have been 'rendering' and not creating a DVD as there are no VOB or IFO files. I'll now try to create a DVD as suggested.
Regards to all !
Bluray discs won't play, but DVDs will.
By WebFixer in forum DVD & Blu-ray PlayersReplies: 11Last Post: 6th Aug 2016, 09:00 -
My recorded BD-R discs won't play on new Blu-ray players
By Bowhunter2001 in forum Blu-ray RippingReplies: 14Last Post: 26th Jul 2015, 07:53 -
VHS to DVD Transfer of multiple home made movies
By wfo1955 in forum Newbie / General discussionsReplies: 8Last Post: 5th Sep 2013, 17:21 -
Major disaster, how do I get home made video off of mini DVD?
By usalabs in forum DVD RippingReplies: 60Last Post: 14th Jul 2013, 20:53 -
Computer-made DVD won't play on DVD player.
By hglr24 in forum Authoring (DVD)Replies: 10Last Post: 5th Jul 2013, 15:55
