  1. Howdy!
    Im wundering if there are any way to make TMPgen work with two files in a sequal, i have splitted an avi movie and i wish to be able to mpeg those without gurading the puter and switching files =P.
    If any of ya readers know any plugin or a way to make it happend il get
    wery greatfull.
  2. Tmpgenc, file menu-> batch encode
    Apr 2002
    Essex, England
    Batch encode can also be selected to shut down your PC when it is finished - very handy if you leave it running overnight or when you go to work!
  4. Originally Posted by q1aqza
    Howdy =)
    Exaktly why ide liek to get that to work but sinve im new on the TMPgen software i dont know how to make that happend, i usualy use the software Video Wave III wich is slower but the quality seems to be better then with TMPgen though.
    I have been experimenting with some 1disc templates but none seem to work as i like so il keep on with two disc system even though it can be a pain in the ass while chewing chips and having cola =P.
  5. To Use Tmpgenc Batch encode do the following.
    Load your 1st avi/audio files. Select your template and make any setting changes you need. Go file-save project. Repeat for your second avi file. Then select file-Batch encode. Click add and add in each of your projects. Click Run. Go to sleep and next morning the encode is complete!
  6. Originally Posted by bugster
    Aah great i managed it thank you wery much =), on me way to VCD Full Metal Jacket and Platoon.
