I have a list of .m4v files. I have a list of .mp3 files (which happen to be the same file name as the corresponding .m4v files).
The .m4v files contain lower quality audio. The .mp3 files contain a better quality audio.
I would like to replace the audio in the .m4v files, with the corresponding audio in the .mp3 files.
I would not like to do this individually for 10000+ files, in either mkvmerge or ffmpeg.
I have tried a batch script with something like this but to no avail:
As well as (as I wanted the output in a different directory):Code:FOR %%a IN ("*.m4v") DO ffmpeg -i "${%%a}" -i "${%%a//.m4v/.mp3}" -vcodec copy -acodec copy "${%%a//.m4v/.mp4}" pause
These so far have been unsuccessful (have only encountered errors). I am not sure how to fix this.Code:FOR %%a IN ("*.m4v") DO ffmpeg -i "%%a" -i "%%a" -vcodec copy -acodec copy "outputDirFoo123\%%~na.mp4" pause
Could someone please indicate how I can batch process what I want above? Is there a better way to do it than I am here?
Many thanks.
Will copy video from file #0 and audio from file #1. Any metadata or subtitles you are worried about?Code:
FOR %%a IN (*.m4v) DO ffmpeg -i "%%a" -i "%%~na.mp3" -map 0:v -map 1:a -c copy "outputDirFoo123\%%~na.mp4" pause
Try to add -map_metadata 1 or -map_metadata:s:a 1:s:a. I'm not sure it will work though as you expect or at all. Metadata from different formats cannot always be copied.
replacing (and syncing) an audio track of an MP4 video file
By rotchild in forum Newbie / General discussionsReplies: 6Last Post: 23rd Dec 2016, 04:32 -
replacing (and syncing) an audio track from an MP4 video file
By rotchild in forum RestorationReplies: 0Last Post: 14th Dec 2016, 20:30 -
Adding lossless audio to video / replacing audio track
By Jacobson in forum Video ConversionReplies: 72Last Post: 29th Jul 2016, 21:05 -
How do I (BATCH) set a specific subtitle track, and audio track as default?
By MountainSplash00 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2014, 06:53 -
mkv replacing audio track and out of sync
By chaussettdeguerr in forum EditingReplies: 6Last Post: 25th Mar 2013, 22:42
:a 1
