Hey..
I wonder what settings are the common one for making vcds..
ion other words, how should i encode video into mpeg?
so that nero doesnt has to RE-ENCDOE the video?
Thankss for help.
Sangofe
The easy way to do it is to load the VCD template in tmpgencd and hit start. It doesn't get any easier or common then that. Using that template you shouldn't have any problems burning w/Nero.
On the lower right corner of Tmpgenc you'll see three buttons, "settings, load and save". Click load, when you do so you will see various templates that you can use to encode your video to a nero compliant format. You'll see something like the following..."SuperVideoCD (NTSCFilm).mcf". All these mcf files are templates, and as far as I know, they are all pre-compatible with nero, so it wont have to re-encode your video. Just make sure that if you choose a VCD template in Tmpgenc that you also choose the vcd option in Nero, and if you choose a svcd template in Tmpgenc that you also choose the coresponding svcd burn option in the nero options.
Where is the wine the new wine? Dying on the vine.
MPEG1 custom GOP settings
By sipposa in forum Video ConversionReplies: 8Last Post: 11th Jul 2011, 20:23 -
GOP control in ffMPEG MPEG1 encoding
By Computer Nerd Kev in forum Authoring (VCD/SVCD)Replies: 12Last Post: 4th Jul 2011, 03:52 -
can i truncate mpeg1 video files without re-encoding?
By dullrazor in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2009, 16:47 -
makin the movie fit
By xstatictravis in forum DVD RippingReplies: 12Last Post: 11th Apr 2008, 09:52 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
