[Attachment 41940 - Click to enlarge]
[Attachment 41939 - Click to enlarge]
Greetings,
I tried loading a movie using the MPC-HC, but when I tried to load subtitle they were on strange unreadable language (for me at least). The subtitles I tried to load were in English, so there shouldn't be any problems with the formats, I am using Windows 10 Pro x64 English version. I tried changing regions from the Administrative panel, changing formats from the player, and loading every possible subtitle file for the current movie. Some help will be appreciated.
Thank you for your time,
Kind Regards!
Simply using the "s" key will cycle through the subtitles available in/with that file (regardless of the language). MPC-HC simply reads the file and displays it, it doesn't convert a file into another language. So as noted above, the file you have is very likely not English. If it's an .srt file, you can open it with any text editor or notepad and view it to confirm.
Google is your Friend
DVDs force subtitle language (MPC HC)
By semmel in forum SubtitleReplies: 6Last Post: 10th Dec 2016, 18:32 -
Potplayer subtitle language issue
By Chaffee in forum Software PlayingReplies: 6Last Post: 10th Dec 2016, 11:41 -
Multi-Language Subtitle DVD
By Shayetet13 in forum SubtitleReplies: 2Last Post: 10th May 2016, 11:41 -
need help about subtitle shown in strange language
By maxtime in forum SubtitleReplies: 21Last Post: 14th Apr 2015, 19:40 -
MPC-BE: how to display datacode (PGS-Subtitle) like in MPC-HC
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 29th Apr 2013, 13:14
