Hi,
I'm having problems with me WhrfM5 with the DVE631fw with the EZpatch to enable MiniDVD, and raw AC3, VOB, MPG file playback.
When the player was still running wharfedale fw it would not play minidvds or DVD+rw. After the firmware it WILL play minidvds and CDrs with Vobs,mpgs etc on it... but it will still not play DVD+rws.
Any ideas? I've tried two brands of media, tried burning raw files to the disks, using NERO to burn DVD-video, and ULEAD DVDMoviefactory to create DVD movies with too... but to avail.
Do you think it might work if I used DVDr? (as opposed to re-writable) - expensive to experiment on tho
Note that the RW disks work fine on the DVD-rw writer and the Creative 5x DVDrom on me PC's.
Has anyone else managed to get DVD+rw's to work on Wharfedale M5's or the DVE631cf?
Results 1 to 1 of 1
