  1. Member thecrock's Avatar
    May 2005
    england
    Hi all, I need a quick way to boost the volume of a mp4 video file. Thanks in advance.
    “He who makes a beast of himself gets rid of the pain of being a man.”
    USA
    I'd probably try Audacity. Most times it can open the audio of a video file you drop into it.
    And boosting volume usually adds noise, so a bit of selective filtering may also help.
    I've used Virtual Dub to mux the modified audio back into the video file and also extract
    the original if Audacity doesn't open it.
    AviDemux is another option if you don't need much in the way of filtering.
    Aug 2010
    San Francisco, California
    You might try aacgain.
