HI,
I have a video file which is vbr, I would like to convert it to a cbr video file, so that i can edit the video with having audio sync problem. I have tried using handbrake but it stops encoding and responding at approx 80% way through encoding. Is there any other simple tool that i can use to convert the video to a cbr one?
Thanks in advance
Results 1 to 14 of 14
Vbr in either video or audio should not affect audio sync with most decent editors. Perhaps you are thinking of VFR?
Scott -
Did you try HandBrake nightly?
Other than that you can use AviSynth:
Code:a=ffaudiosource("sourcefile") v=ffvideosource("sourcefile", fpsnum=30000, fpsden=1001) #example for 29.97 fps. change values according to the target framerate you want AudioDub(v, a)
(like Cornucopia I'm assuming you meant vfr, not vbr) -
The nightly build of handbrake didn't work, how do i use avisynth?
I tried creating a .avs script with the coding you gave. however i get on error - script error: there is no function named "ffaudiosource"
Thanks in advanceLast edited by brandcc; 18th Jun 2017 at 02:55.
Thank you, how do i use that please?
I copied the ffms2 plugins (ffms2.dll, ffms2.lib and ffmsindex.exe) into the AviSynth\plugins folder.. now i get the error - "the script's return value was not a video clip, (is the undfined value)."Last edited by brandcc; 18th Jun 2017 at 04:28.
same error message when i used a different video file. The video file is a mp4 (x264)
You still didn't clarify exactly. Variable bitrate is perfectly normal for video, whereas a variable frame rate might cause sync problems when editing, depending on the program.
You could try AviDemux. If you click the Filters button, then select the Transform filters list on the left, it includes a filter called "Resample FPS".
AVIDemux will also do basic editing. I wasn't sure how it'd handle VFR source files, so I gave it a VFR MKV as a test. Without using the "Resample FPS" filter it output the average frame rate and the audio was out of sync. When I used "Resample FPS" it was fine. I tried a few quick edits, and that didn't seem to bother it, even for the VFR source.
If you want to simply cut out sections or re-arrange them, you can do so and save the output using "copy" for the video and audio so there's no re-encoding required. I tried cutting and pasting a few sections of my VFR MKV and then saved it without re-encoding, and the audio sync was fine. -
MKV to MP4, does vbr changes to cbr?
By socrates in forum Video ConversionReplies: 13Last Post: 10th Oct 2015, 21:38 -
Converting a m2v file to mp4
By jaymjay in forum Video ConversionReplies: 3Last Post: 22nd Jan 2015, 11:29 -
Converting from MP4-AVC to AVI-MP4(xvid)
By GruntVidStar in forum Video ConversionReplies: 24Last Post: 23rd Apr 2014, 15:34 -
SUPER converter: difference between MP4 file and Android (MP4)?
By mindstormer in forum Video ConversionReplies: 12Last Post: 30th Jan 2013, 05:15 -
mp4 file not playing in an application that supports mp4 files
By mindstormer in forum Video ConversionReplies: 2Last Post: 1st Jan 2013, 21:17
