I get vocal / Instrumental versions of the song
I used Adobe Audition and applying the Effects/Invert option in Instrumental version , but it didn't work
Can anyone help me to extract vocals from this song ?
Here are two MP3 files
https://mega.nz/#F!OtgjwKBD!_Mg11jbWgN50mxm0X6GQBA
Try to increase separation between channels (widen stereo) - vocal is usually located in center as such it should be significantly reduced after "stereo widening" try to use such "instrumental" version to remove everything else (subtract "instrumental" from source).
You could use the phase inversion method unfortunately I'm afraid you can't with this two files because they're not exactly the same. Instrumental way too different.
If A + B = C, then C - B = A. But you actually only have C & D. Mixing Math alone cannot fix this.
Song data
By suadnovic in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2016, 08:09 -
Need help taking vocals off a song!
By buzzman03 in forum EditingReplies: 6Last Post: 5th Jul 2015, 20:48 -
Need this particular song asap :(
By langf in forum AudioReplies: 21Last Post: 29th Apr 2015, 14:00 -
Best professional software for removing vocals from video
By Video001 in forum AudioReplies: 6Last Post: 26th May 2014, 01:50 -
Amplifying distant sounding or muted vocals
By headless chicken in forum AudioReplies: 3Last Post: 5th Jan 2013, 19:14
