I couldn't encode in cce, mailed the support they have with the info, and they said
It seems that you have not installed vifp codec (VFCodec.dll). Please install the codec and try again.
1stly, i can't find the vifp codec to download anywhere.
2ndly what is the best codec to use?
3rdly, i've tried to install another codec, but cce still doesn't like encoding? still trying to look for the vifp codec?
Thanks for any help
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which codec should I use?
By TSWatson in forum ProgrammingReplies: 9Last Post: 23rd Apr 2010, 07:25 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Dv Codec
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th May 2008, 13:10
