I have a Sony HDTV and also have a DVB card on my PC for watching satellite TV. Already I can stream channels through network using Progdvb or Dvbdream. DVBdream only support "UDP" streaming but Progdvb have more options for streaming, it support "Over HTTP"(a HTTP address that show channel names and file with m3u8 format), "IPTV", "Windows media streaming".
As far as I know my HDTV does not recognize this type of streams. It's only support DLNA. Is there any software solution(for Windows) to get live stream from Progdvb or Dvbdream and DLNA that to HDTV?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I would say no, as you are mixing two technologies. In the case of your DVB card, you have a means to stream the broadcast as it's received.
DLNA uses a DLNA server on the host machine to read files from the HDD and then stream them to devices on the connect (in simple terms). The DLNA server only reads stored files, it doesn't intercept and convert incoming streams. Maybe I'm wrong, and someone can offer a solution.
The easiest solution would be to simply get a SAT receiver to connect to the TV, unless there is a third party app that can receive the DVB stream.Google is your Friend -
Windows Media Player has the ability to act as a DLNA server. If you can get it to play your DVB channels (I can play channels from my HD HomeRun cablecard device) it should be able to stream them to your TV via DLNA.
I can get DVB channel with Windows Media Player by using Open URL but when I want to send it to HDTV(Cast to Device), it say that there's no item in playlist. Actually WMP does not recognize the url in playlist as an item to cast to device.
URL= http://192.168.10.24:10999/id/800134C3.0082000000BC04D0.3678
Is there a Quad DVB-S2 PCI-E card also with at least 1 DVB-T2 tuner?
By bergqvistjl in forum CapturingReplies: 1Last Post: 8th Apr 2016, 10:41 -
Is it possible to use DLNA to stream DV AVI from PC to TV or Bluray player
By Movie-Maker in forum Newbie / General discussionsReplies: 15Last Post: 8th Feb 2016, 15:35 -
Help to watch live tv from DVB-T
By saalhaga in forum DVB / IPTVReplies: 5Last Post: 18th Nov 2014, 16:08 -
how to stream over the internet a dvb-s2 card?
By nikolaos1983 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Jul 2013, 05:27 -
How to stream Multiple Tv Program Live On Website by using Internal Tv Card
By monimukto in forum Video Streaming DownloadingReplies: 1Last Post: 28th Sep 2012, 10:41
