Dear all,
I made a small introduction video that I need to apply for work, and my laptop creates this incredible, high pitched background noise. I tried the obvious in Audacity, I killed the sound, but to the cost of a totally muffled sound.
Would anyone know, if it is still possible to save this video? I find it really good and would not like to make it from the mobile phone one again.
Any ideas appreciated.
Here is the link to the video:
https://www.youtube.com/watch?v=HV1FgaXe9Ds&t=2s
In Audacity:
Mark a second or two of just the noise at the start (or elsewhere) of the clip. Use Effect -> Noise Reduction -> Get Noise Profile. Then mark the entire clip and select Effect -> Noise Reduction, set Noise reduction to about 20 dB. Press OK. That should work pretty well. The higher the NR setting the more distortion you'll get.
Alternate method:
Mark a second or two of just the noise at the start (or elsewhere) of the clip. Use Analyze -> Plot Spectrum to see a graph of frequencies. Enlarge the Window to full screen for best accuracy. Take note of the frequency of the highest peaks. I got 738, 884, 3494, 4000, and 4505 (the latter three are responsible for most of the whine). Mark the entire clip then select Effect -> Notch filter. Set Frequency to one of those peaks. Set Q to 12 (very narrow frequency range). Press OK. Repeat for each of the peaks. A sample with just the three highest frequencies remove is attached.Last edited by jagabo; 16th Jun 2017 at 10:08.
That is so amazing! I did all that yesterday, but only for the highest pitch, it somehow did not cross my mind - although it is so logical - to simply repeat the process for the other frequencies. Thank you so much for your input, I was about to give up.
Thanks a million for your great help!
You're welcome.
By the way, in the future use a lapel mic or a boom mic. The idea is to get the mic as close as possible to the person speaking. You'll get a much clearer voice, and less noise and echo. Of course, this may not be possible with a smartphone.Last edited by jagabo; 16th Jun 2017 at 12:44.
Improve blurry low quality video into clear high quality video.
By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 01:48 -
On the video background
By Faiyadh in forum Newbie / General discussionsReplies: 12Last Post: 20th Sep 2013, 11:19 -
tmpgenc video mastering works 5 "clear all gaps" options
By mvp in forum Newbie / General discussionsReplies: 0Last Post: 18th Sep 2013, 20:23 -
TMPGEnc-menus background going to green screen or previous menu background
By DwightFry78 in forum Authoring (DVD)Replies: 0Last Post: 31st Jul 2013, 14:11 -
Change background of video
By duccorleone in forum EditingReplies: 60Last Post: 27th Oct 2012, 14:39
