I noticed that 4k rip movies have washed out colors comparing to 1080p bdrips and why is that? Maybe I should change some settings in player? I don't know...
I'm using pot player. I will show example now how they look, so you understand my problem better:
At the left side is 4k video & at the right side is just bdrip 1080p
4k video info:
General
Unique ID : 191560444355941376435234751949353448215 (0x901D3318A06DC2BF8CC83E916676F317)
Complete name : E:\Downloads\Inferno.2016.2160p.UHD.BluRay.HDR.DTS .x265-ULTRAHDCLUB.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 32.2 GiB
Duration : 2 h 1 min
Overall bit rate : 37.9 Mb/s
Movie name : Inferno (2016) - Release for ULTRAHDCLUB
Encoded date : UTC 2017-06-13 22:11:50
Writing application : mkvmerge v9.9.0 ('Pick Up') 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 35.7 Mb/s
Width : 3 840 pixels
Height : 2 076 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Original frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.187
Stream size : 30.3 GiB (94%)
Title : Inferno (2016) - Release for ULTRAHDCLUB
Writing library : x265 2.4+6-fd01abfc7898:[Windows][MSVC 1910][64 bit] 10bit
Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=12 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2076 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=3 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=0 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=2 / subme=7 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / no-deblock / no-sao / no-sao-non-deblock / rd=6 / no-early-skip / no-rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=3.00 / psy-rdoq=6.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=22.5 / qcomp=0.80 / qpstep=1 / stats-write=0 / stats-read=0 / vbv-maxrate=100000 / vbv-bufsize=100000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.10 / pbratio=1.00 / aq-mode=3 / aq-strength=1.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=51 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP (15635,16450)L(40000000,50) / max-cll=10000,3647 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / refine-level=5 / no-limit-sao
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : SMPTE ST 2084
Matrix coefficients : BT.2020 non-constant
Mastering display color primar : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
Maximum Content Light Level : 10000 cd/m2
Maximum Frame-Average Light Le : 3647 cd/m2
1080p video info:
General
Unique ID : 202150672451829701536318141010544877525 (0x9814CDA761D6F30BA3108CBC6C82DFD5)
Complete name : E:\Downloads\Inferno.2016.1080p.BluRay.Rus.Ukr.Eng .HDCLUB.mkv
Format : Matroska
Format version : Version 2
File size : 14.8 GiB
Overall bit rate : 17.5 Mb/s
Movie name : Inferno (2016) - Release for HDCLUB
Encoded date : UTC 2017-01-17 20:00:00
Writing application : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Width : 1 920 pixels
Height : 1 040 pixels
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Title : Inferno (2016) - Release for HDCLUB
Writing library : x264 core 148 r2721.18 cd45d75 VietHD_Custom_64
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=56 / lookahead_threads=8 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=19.4000 / qcomp=0.65 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.30 / pb_ratio=1.20 / aq=3:0.90 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Language : English
Default : Yes
P.S. I'm using HDMI cable from my graphics card to my monitor
Closed Thread
ditendra, it is a violation of our rules to discuss downloaded, copyrighted videos.
Please read our rules before posting concerning warez.
https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)
Thread closed.
Moderator redwudz
why do most movies blu-ray and dvd's colors look dull and dark
By jamespoo in forum MediaReplies: 11Last Post: 15th May 2016, 18:20 -
Vegas blurried washed out output
By Danny1 in forum EditingReplies: 4Last Post: 12th Jul 2015, 11:47 -
Is this true?Women see less colors than men, and they see washed out colors
By Stears555 in forum Off topicReplies: 5Last Post: 10th Jul 2014, 14:07 -
washed out colors on most player (fraps - lagarith - megui)
By modar in forum Video ConversionReplies: 14Last Post: 13th Mar 2014, 05:16 -
Converted Videos look Washed Out
By Track in forum Video ConversionReplies: 39Last Post: 27th Mar 2013, 10:46
