I hope someone can help with this issue. A client is sending me videos recorded with iPhone; with dual-channel MONO AAC-LC audio, an average of 89 kbps. It's mono but dual-channel. I'm editing with Premiere Pro, and on export, I choose H.264 with AAC-STEREO. (I guess it does not change anything it's still a mono duplicated in both channels?) But I'm choosing Stereo because I'm also using another short Stereo AAC 192 kbps track in the same project, although 90% of audio in this project is 89 kbps.
The question is:
Export have to be in AAC format, so please don't suggest to convert to another format. Thanks!
- Should I keep the closest bitrate on export (96kbps) or upsample to 192kbps if I choose Stereo on export, or because of that other audio. Just want to keep best possible quality and not sure if upsampling is beneficial or it could degrade the quality of 89kbps audio?
If your stereo content sounds better at 192k, then export the whole project that way. It won't hurt your 96k source.
Lossily re-encoding from lossy sources is always going to be "worse" than the source, but maybe not noticeably worse. Esp. if you keep an equal or higher bitrate.
If even a small portion of your material is in stereo, and enjoyment is improved/maintained by keeping it that way, it makes sense to mark the whole exported track/stream as stereo. And accordingly, your bitrate should be higher (~2x mono).
Can I keep mono audio on AAC?
By synnchan in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2016, 11:37 -
Which audio setting should I selected in XMedia? AAC or AAC (Faac)
By Greg2041 in forum AudioReplies: 3Last Post: 1st May 2013, 08:17 -
Higher 2.0 AAC bitrate from Ripbot
By jntaylor63 in forum Blu-ray RippingReplies: 6Last Post: 3rd Nov 2012, 17:22 -
Converting AVCHD with Stereo AAC into AC3
By Mark97213 in forum Video ConversionReplies: 3Last Post: 20th Aug 2012, 12:51 -
AAC stereo vs AAC mono
By elmuz in forum AudioReplies: 23Last Post: 5th Jul 2012, 23:47
