Here is the media info of the file
Count : 325
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Inform : MPEG-PS: 9.56 GiB, 1 h 58 min
Count of video streams : 1
Count of audio streams : 1
Count of menu streams : 1
Video_Format_List : AVC
Video_Format_WithHint_List : AVC
Codecs Video : AVC
Audio_Format_List : AAC
Audio_Format_WithHint_List : AAC
Audio codecs : AAC LC
Menu_Format_List : DVD-Video
Menu_Format_WithHint_List : DVD-Video
Menu codecs : DVD-Video
File extension : mpeg
Format : MPEG-PS
Format : MPEG-PS
Format/Extensions usually used : mpeg mpg m2p vob pss evo
Commercial name : MPEG-PS
Internet media type : video/MP2P
Codec : MPEG-PS
Codec : MPEG-PS
Codec/Extensions usually used : mpeg mpg m2p vob pss evo
File size : 10266746270
File size : 9.56 GiB
File size : 10 GiB
File size : 9.6 GiB
File size : 9.562 GiB
Duration : 7120640
Duration : 1 h 58 min
Duration : 1 h 58 min 40 s 640 ms
Duration : 01:58:40.640
Duration : 01:58:40:16
Duration : 01:58:40.640 (01:58:40:16)
Overall bit rate mode : VBR
Overall bit rate : 11534633
Overall bit rate : 11.5 Mb/s
Frame rate : 25.000
Frame rate : 25.000 FPS
Frame count : 178016
File creation date : UTC 2017-06-15 00:47:07.705
File creation date (local) : 2017-06-14 19:47:07.705
File last modification date : UTC 2017-06-15 00:46:18.178
File last modification date (local) : 2017-06-14 19:46:18.178
Video
Count : 338
Kind of stream : Video
StreamOrder : 3
FirstPacketOrder : 0
Inform : 1280*720 (16:9), at 25.000 FPS, AVC (Baseline@L3.1) (1 Ref Frames)
Format : AVC
Format/Url : http://developers.videolan.org/x264.html
Commercial name : AVC
Format profile : Baseline@L3.1
Format settings : 1 Ref Frames
Format settings, CABAC : No
Format settings, ReFrames : 1
Format settings, ReFrames : 1 frame
Internet media type : video/H264
Codec : AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : http://developers.videolan.org/x264.html
Codec profile : Baseline@L3.1
Codec settings : 1 Ref Frames
Codec settings, CABAC : No
Codec_Settings_RefFrames : 1
Duration : 7120640
Bit rate mode : CBR
Bit rate mode : Constant
Nominal bit rate : 2560000
Nominal bit rate : 2 560 kb/s
Width : 1280
Width : 1 280 pixels
Height : 720
Height : 720 pixels
Sampled_Width : 1280
Sampled_Height : 720
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Display aspect ratio : 16:9
Frame rate : 25.000
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Scan type : Progressive
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.111
Delay : 200.000
Delay : 200 ms
Delay : 200 ms
Delay : 200 ms
Delay : 00:00:00.200
Delay, origin : Container
Buffer size : 5120000
Audio
Count : 275
Kind of stream : Audio
StreamOrder : 4
FirstPacketOrder : 1
Inform : 44.1 kHz, 2 channels, AAC (ADTS) (Version 4) (LC)
Format : AAC
Commercial name : AAC
Format version : Version 4
Format profile : LC
Muxing mode : ADTS
Codec : AAC LC
Codec : AAC LC
Duration : 7120608
Duration : 1 h 58 min 40 s 608 ms
Duration : 01:58:40.608
Bit rate mode : VBR
Bit rate mode : Variable
Channel(s) : 2
Channel(s) : 2 channels
Channel positions : 2/0/0
ChannelLayout : L R
Samples per frame : 1024
Sampling rate : 44100
Sampling rate : 44.1 kHz
Samples count : 314018816
Frame rate : 43.066
Frame rate : 43.066 FPS (1024 spf)
Compression mode : Lossy
Delay : 200.000
Delay : 200 ms
Delay : 200 ms
Delay : 200 ms
Delay relative to video : 0
Delay relative to video : 00:00:00.000
Video0 delay : 0
Video0 delay : 00:00:00.000
Menu
Count : 92
Kind of stream : Menu
Format : DVD-Video
Commercial name : DVD-Video
Codec : DVD-Video
Codec : DVD-Video
Please some one help to fix the video
MPEG-PS is a program stream. It might/could be a proprietary file format as mentioned in other posts. What device produced this video? Where did you get this video?
The format/url produces a dead link. I don't know why that is there.Extraordinary claims require extraordinary evidence -Carl Sagan -
Some forms of drm have the video in the clear for the first 5-10 seconds of the video before the encryption starts. If there is any possibility that your video was sourced from a provider using drm, this could be the cause of what you see.
He already knows it's encrypted:
https://forum.videohelp.com/threads/383944-Downloaded-MPEG-PS-Media-clip-stream-from-D...elp-to-mkv-mp4 -
bro did u get any solution for this... Even i am having the same problem
MKV File Audio OK When Played From PC, Garbled When Played From TV
By 1voyager1 in forum AudioReplies: 10Last Post: 6th Jan 2017, 03:22 -
Add Subtitles for the first few seconds of a video
By anime12345 in forum SubtitleReplies: 1Last Post: 22nd Feb 2016, 15:22 -
Handbrake Speeding up Video by 9 seconds
By DJ Omega in forum Video ConversionReplies: 8Last Post: 3rd Jun 2015, 23:57 -
creating a few seconds of 'freeze' within a video
By pooksahib in forum EditingReplies: 9Last Post: 27th Oct 2012, 11:12 -
Macroblocks only at the first seconds of the video
By fernandovg in forum Video ConversionReplies: 9Last Post: 22nd Jun 2012, 10:29
