Hi everyone, I have been downloading "Malcolm In The Middle" from the site Hotstar. It is free to watch this show so it isn't a paid to watch video.
However I have successfully downloaded the first 3 seasons using youtube-dl and FFMPG using code below
was working fine up until about 6 days ago when i now recieve this errorCode:youtube-dl.exe http://www.hotstar.com/tv/malcolm-in-the-middle/12117/if-boys-were-girls/1000114290
I wasnt using A VPN as it was working fine without one (Australia) but some episodes from S01 and S02 required a "Mumbai" server on Express VPN to be used.Code:C:\Users\Ben\Downloads\Compressed\ffmpeg-20170503-a75ef15-win64-static\bin>youtube-dl.exe -v http://www.hotstar.com/tv/malcolm-in-the-middle/12117/grandma-sues/1000114289 [debug] System config: [] [debug] User config: [] [debug] Custom config: [] [debug] Command-line args: ['-v', 'http://www.hotstar.com/tv/malcolm-in-the-middle/12117/grandma-sues/1000114289'] [debug] Encodings: locale cp1252, fs mbcs, out cp437, pref cp1252 [debug] youtube-dl version 2017.06.05 [debug] Python version 3.4.4 - Windows-10-10.0.15063 [debug] exe versions: ffmpeg N-85750-ga75ef15, ffprobe N-85750-ga75ef15 [debug] Proxy map: {} [HotStar] 1000114289: Downloading JSON metadata [HotStar] 1000114289: Downloading JIO JSON metadata [HotStar] 1000114289: Downloading m3u8 information WARNING: Failed to download m3u8 information: HTTP Error 502: Bad Gateway ERROR: No video formats found; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output. Traceback (most recent call last): File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\build\youtube_dl\YoutubeDL.py", line 761, in extract_info File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\build\youtube_dl\extractor\common.py", line 433, in extract File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\build\youtube_dl\extractor\hotstar.py", line 89, in _real_extract File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\build\youtube_dl\extractor\common.py", line 1056, in _sort_formats youtube_dl.utils.ExtractorError: No video formats found; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output. C:\Users\Ben\Downloads\Compressed\ffmpeg-20170503-a75ef15-win64-static\bin>pause Press any key to continue . . .
But now I just cannot get it to work, and whats more annoying is I feel I may be blocked somehow, as I could actually watch the show in browser on the Mumbai server but can now only watch on Chenai server, but no matter what server I pick I cannot get youtube-dl to work.
I have also tried Hotstarlivestreamer and I get this error
I would love some help with this asap as the show will be taken off in 14 days and this is the only possible way to get it all in HD as netflix doesn't have S06 and S07 in HD,Code:paste the link:http://www.hotstar.com/tv/malcolm-in-the-middle/12117/if-boys-were-girls/1000114290 Available streams: 234p 360p 404p 720p 900p 1080p write quality (example write 720p):1080p play or download? (write p or d):d Starting livestreamer... The system cannot find the path specified. Done. Press any key to continue . . .
Also admin/moderators of this site, this is purely for my own viewing, I have the dvd's but want to have it in HD
Tubedigger ($15) with vpn got it.
Link to video:
https://files.videohelp.com/u/61125/in.mp4 -
only 720p Im guessing with that small of a filesize, youtube-dl was getting 1080p and around 700mb filesize
Update have tried hotstarlivestreamer by biezom and it is working, is their a way to queue up multiple links though so I can just start program and leave it to do its thing
Could anyone tell me some general information about
hotstarlivestreamer by biezom?
For example, does it download without a vpn if you are outside of India? If so, how can it do that?
Can someone provide a simple example using
hotstarlivestreamer.
I need to see a specific example of downloading ( post the command line output from beginning to end, so I can see how to use it.
I know there is information on Github about this, but it is too complicated for me to follow. I just need one good specific example and then I can figure it out.
Thanks.
DeletePost
By PowerFalcon in forum Video Streaming DownloadingReplies: 0Last Post: 10th Apr 2017, 20:23 -
An issue and some questions about Youtube playlist in PotPlayer
By Hanyuu in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2017, 16:45 -
youtube upload issue
By Baboshka in forum Newbie / General discussionsReplies: 15Last Post: 10th Jun 2016, 09:30 -
Youtube RTMP Protocol issue.
By mikehende in forum Video Streaming DownloadingReplies: 15Last Post: 18th Mar 2015, 14:26 -
YouTube Playback Issue on Uploads
By Database Ranger in forum Video Streaming DownloadingReplies: 10Last Post: 6th Nov 2012, 16:16
