Does anyone have frame serving working with Virtual dub version 1.4.10.
I just downloaded it yesterday, I reinstalled the stuff in the aux setup (what ever it was called) and turned the proxy server on with the registry setting file, but TMPGEnc refused to read the signpost file (so did another instance of Virtauldub!). I've done frameserving to TMPGEnc hundreds of times before, so I know what I'm doing, and know it should work.
I gave up and put back version 1.4.9 and it worked fine, so I suspect a problem in the new revision. If anyone does have it working, was there anything special you needed to do?
You need to add a file msvcr70.dll to your windows/system32 directory.
If you do a search on the web you should be able to find it many places as it is a free file. The frameserver portion was recompiled with the latest MScompiler and needs this support file.
Take care,
Mike H. -
Have a look at the following post.
http://www.vcdhelp.com/phpBB/viewtopic.php?t=87293
It gives a possible solution to your problem.
Best regards,
Ronin2 -
Thanks guys.
It doesn't really seem like they solved it in that other thread, but at leat I know I'm not alone.
mikehg, I will look for that file and give it a go. It sounds very promissing. -
OK, I tried it (msvcr70.dll ) and it FIXED the problem.
Fantastic.
Thanks again!!!!!
Can you use frame serving for video conversions?
By johnharlin in forum Video ConversionReplies: 2Last Post: 2nd Mar 2011, 23:39 -
Resizing(Frame Size) w/ VIRTUALDUB - PLEASE HELP!!!
By MDrumm in forum EditingReplies: 8Last Post: 17th Jan 2011, 03:12 -
Frame serving
By carlmart in forum Video ConversionReplies: 2Last Post: 2nd Jul 2009, 09:39 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24 -
Virtualdub: the key frame displayed is off
By cheerful in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 13:28
