  1. Used DVDit PE to author a DVD-R containing 4 MPEG-1 files. De-multiplexed the files, used DVDit's encoder to convert the audio to Dolby Digital. I loaded the VIDEO-TS folder into Cinematograph, and it played perfectly. All menus worked, all video files played, etc.
    However, when i burned the disc with my DVR-104, and then tested it, the audio is was HORRIBLY out of sync with the video. Each file would start in sync, and then gradually go out of sync as the video progressed. Ten minutes into each video file, the audio was off by several seconds.
    Anyone know how i can fix this?
  2. Have seen similiar problems myself and its quite strange. Doesnt seem to happen on all movies either. If I put in chapter points, then the audio seems to return to sync at each chapter point then drift out again. The problem doesnt happen if you use PCM audio but this is not always feasible due to the HUGE amount of space it takes up. Other than this I have not found a solution, anyone else help?
  3. i get the same probs with ulead dvd studio might try making diff chapters might sort it out
