Hello,
I am a noob in DVD Ripping and i want to Rip some i own just to throw them away because of space reasons and place the resulting Videos on a Media Server.
All are AC3 5.1(48kHz) 384kbs
I can do AC3 Passthru and everything works ok but i found out that some Android devices do not want to play because the audio track is AC3
If I change to AAC everything works.
Now here is the question:
In Handbreak what is the correct setting to encode AC3 5.1(48kHz) 384kbs into AAC(avcodec)?
What is the correct Bitrate? 384kbs like the original AC3?
What is the correct mix? 5.1 ? Dolby Pro Logic II ? Dolby Surround?
Because I want to throw away the DVDs I will Rip them with all audio tracks and subtitles cause if i want to ever get back to them, to have something decent to work on(maybe re-encoding in a different video format in the future as technology evolves and players aren't compatible anymore with old formats etc) so i would like to preserve the audio track as close to the original, not to lose to much quality.
thx in advance
	I'm not sure Android ever supported AC3 as such, but you can install a player that does. Apparently Dolby started going after developers of non-free players or players that have paid versions (for licence fees), but there's free players that support AC3. For example,
 VLC https://play.google.com/store/apps/details?id=org.videolan.vlc
 AC3 Player https://play.google.com/store/apps/details?id=nppl3.hd.video.player
 My favourite player removed AC3 support from it's free version a fair while ago, but you can install a separate codec for decoding AC3 yourself.
 MX Player: https://play.google.com/store/apps/details?id=com.mxtech.videoplayer.ad
 Custom codecs: https://forum.xda-developers.com/apps/mx-player/mx-player-custom-codec-dts-support-t2156254
 You can keep the original AC3 and convert it to AAC too. It won't make the files all that much bigger unless there's several audio tracks. I thought that's what Handbrake did by default but I don't use it so maybe I'm remembering wrong.
 If you want to keep the original video quality too, you can rip DVDs with MakeMKV. It doesn't re-encode. It just puts everything in an MKV container.
  MKV, AAC Or AC3By jamesj84 in forum AudioReplies: 40Last Post: 30th Sep 2017, 06:20
  How to convert AAC to AC3By newyear1967 in forum User guidesReplies: 11Last Post: 23rd Jul 2016, 18:27
  Ac3 to fdk-aacBy Mildragon in forum AudioReplies: 8Last Post: 4th Jan 2016, 14:06
  AAC vs AC3By rdeffley in forum AudioReplies: 7Last Post: 22nd Dec 2014, 00:45
  Handbrake - AC3 5.0 Ch - Can't maintain 5.0 Ch to AAC or AC3(ffmpeg)By kingaddi in forum DVD RippingReplies: 30Last Post: 26th Aug 2012, 20:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
