Hi,
Using Pinnacle Studio 20, I just finished editing a small movie (animated slideshow from jpg pictures with different resolutions).
I have encoded it in mp4 ultra HD (2.81 GB). The quality is very good (as good as the original jpg files).
I also would like to give it on DVD. If I use Pinnacle (using best quality for DVD), the files generated in the "VIDEO_TS" directory weighs 1.08 GB and the quality is much worse than the mp4.
Not seeing how to improve the result with Pinnacle, I then looked for a way to re-encode my mp4 to DVD.
I did several trials with XMedia Recode, but all give a very poor quality until now.
Would anyone have advice
- either to improve quality from Pinnacle
- or on how to re-encode my mp4
Thank you in advance and excellent weekend.
Fab
Go back to your original project and output it as DVD or DVD compatible mpeg2.
I'm not familiar with Pinnacle's software, but just as a general comment: the DVD video format is not capable of "Ultra HD" resolution. Any path you take to converting this MP4 into a standard dvd that can be played on standard dvd hardware will be downconverted to a resolution supported by the 1997 dvd spec. Not saying you can't somehow make a decent dvd from your slide show, but limitations of the format may prevent it being exactly as good as your original.
Perhaps you can just burn data dvds of your original MP4, and give those out instead? Or get a few cheap 4GB thumb drives, copy the file to them, and give out those? Anyone with a blu-ray player should be able to play your MP4 straight-up as-is in full resolution. Everyone else can just play it on their computers. -
You're source is 3840x2160 and you're making a 720x576 DVD from it. Of course you're losing image quality. DVD doesn't support HD video. 720x576 is the max.
Many people will have problems playing 10 bit 3840x2160 h.264 MP4 file. Make an 8 bit 1920x1080 version if you want others to be able to play your video. -
Thank you all for your time.
I better understand the limitation.
I'll use USB keys.
Have a nice week-end
Fab
how can i join two videos a1.mp4 + a2.mp4 = a12.mp4
By sommers in forum Newbie / General discussionsReplies: 14Last Post: 8th Jun 2017, 18:01 -
Homemade mp4 files quality vs. ripped movies in mp4 format
By MrMX in forum Newbie / General discussionsReplies: 11Last Post: 26th Nov 2015, 22:12 -
Plain English Guide to MP4Box and Repacking MKV-MP4, MP4-MP4 (M4V).
By raregrit in forum Video ConversionReplies: 3Last Post: 8th Jul 2013, 12:52 -
mp4 file not playing in an application that supports mp4 files
By mindstormer in forum Video ConversionReplies: 2Last Post: 1st Jan 2013, 21:17 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 13:36
