Not sure if i'm in the right section or not but i am capturing.
I have been capturing a whole load of old Hi8 tapes without any issue, but there was one tape unlike the others that seems to have problems.
Its a Sony Hi8 Metal-E (E5-60HMEX PAL 75). All the rest were Sony Hi8 Super MP.
The problem i am having is that it keeps intermittently squeaking/struggling as its playing, causing disruption to picture and sound.
Its not the heads as all the other tapes were perfect, so it has to be the actual tape, could it be degradation? The last thing recorded on it says mid 2000s which is in LP.
It seems to play alright in fast forward for some reason.
I don't think its due to incorrect storage, as it was with all the others which were perfect when capturing.
Any ideas of how i could solve this, or is it just old and knackered?
Thanks,
V.
i'd ff/rw it a couple times, but all EP recorded DV is sketchy. usually only the cam that recorded them can play them back well. sometime a pro deck with adjustable tracking can but they are hard to come by these days.
Yeah, im playing it using the original cam.usually only the cam that recorded them can play them back well.
Hi8 doesn't use control track and the only way to change the tracking is by service adjustment. If there is a pro VCR with a tracking knob on the front, I would like to know which one 'cause I could use it!
For this problem tape, here is something you might try. Put the camera with the tape in the refrigerator for several hours, then run cables past the door seal and try playing with the cam still inside the fridge. -
Richard Hess uses that method for squealing audio tape.
Have you tried opening the cassette shell to see if anything stuck between the reels interfering with their locking mechanism? Also it is a good idea to clean the tape path inside the cassette with alcohol to make sure the back side of the tape is not grabbing.
Is it safe to store mini-dv/DAT/Hi8 tapes in a metal filing cabinet?
By Gil T Remnant in forum MediaReplies: 5Last Post: 25th Jan 2017, 10:27 -
Audio Issues Sony MiniDV Tape w/Sony DCR-HC46 cam
By tarana in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Aug 2015, 21:35 -
Sony Hi8 blurred line at bottom of video
By LostEncoder in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th Jan 2014, 12:58 -
Sony Hi8 --> Videograbber Artifacts
By Cebion in forum Capturing and VCRReplies: 1Last Post: 8th Jun 2013, 14:54 -
Using sony hi8 as video capture device
By Jim Jackson in forum Capturing and VCRReplies: 14Last Post: 3rd Mar 2013, 04:51
