Hello everyone. English is not my main language so I must watch with sub. Also I must hardcode subtitle to video because my television doesn't support any subtitle files.
As I know it, There isn't way to hardcode without render. So, what is the fastest way to render? or rather, what is the fastest program on same quality settings.
Note:
I have got RX 480. I can use GPU acceleration.
The fastest way is single pass bit rate mode. File size mode is equivalent to bit rate mode really because file size = bit rate * running length of video. But the video quality will stink. No way around that.
Next fastest is constant q mode or crf. You don't have as much control over the file size but the quality is about the best and it's faster than 2 pass encoding.
No, you cannot hardcode subs without re encoding. I'm not sure GPU acceleration will help that much and quality tends to suffer there.
All those encoders are similar re speed ... there's no magic encoder. The only reason some say that their encoder is faster is that they default to super fast settings (that give you terrible quality).
You don't say which video formats your TV will accept but it's likely xvid or x264. For encoding to xvid I like Avidemux and for x264, Handbrake or Vidcoder, which is Handbrake with a different interface.
There are many other encoders but video encoding is complicated and there isn''t really any way to simplify it all that much. The "easy one click" variety of encoders give you terrible video. There are a lot of others who many video geeks will recommend which can give you great quality. But note I said "can give you ...". They're too hard for novices to use. Avidemux and Handbrake have a good compromise between power and easiness of use. -
Thanks for reply.
I use both. They are so simple and useful program. But I have a question. Vidcoder doesn't support GPU acc. and when I switch settings to openCL(GPU acc.), the program is crash.
Also I am changed my GPU because of some problems. I'm using Asus GTX 1060 Strix 6G now. -
Hardcoding subtitles with Handbrake
By stevenspasperg in forum Video ConversionReplies: 1Last Post: 7th Jul 2016, 15:48 -
Hardcoding Subtitles to the Movies
By Smoke n Fly in forum SubtitleReplies: 3Last Post: 3rd Dec 2014, 12:03 -
Help with Hardcoding Subs
By Audacious in forum SubtitleReplies: 7Last Post: 31st Mar 2014, 18:46 -
Hardcoding with Avidemux
By suzieshooter86 in forum SubtitleReplies: 6Last Post: 18th Jun 2013, 06:28 -
Hardcoding an unicode subtitle to a video
By coldbreeze16m in forum SubtitleReplies: 16Last Post: 9th Oct 2012, 22:41
