  1. A few hours ago, I have packed the files into Rar archive. Then I decided to check everything I packed and WinRAR has gave an error message when opening archive: Invalid or corrupt authenticity information. I don't know where to make downloading rar recovery software.
  2. Anonymous
    Guest
    Did you add recovery options to the rar archive when you made it?
    Can you open the archive with winrar? if so can you extract the files in a readable state?
    I hope you do kept the original files?
    If all not i think your out of luck..
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Any bets this is spam or someone trying to crack a passworded RAR file?
  4. Anonymous
    Guest
    @hech54
    It might be though...i just assume people are honest here..
    And if not, good luck cracking a rar password protected archive!! haha
    (this is nearly impossible, and brute force will take years)
  5. Member leghorn's Avatar
    Apr 2007
    Germany
    That Rar message shows in case of "wrong password". So I do comply with hech54. OP most likely has some password protected archives, possibly pirated, which he/she can't unpack.
    @OP (nagynev21):
    (A) If this request of yours does concern pirated stuff, don't expect any help. Ever.
    (B) Next time choose a more descriptive title.
    (C) Search the internet for password recovery software.
    Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
  6. Anonymous
    Guest
    The Archive has been created using an -av switch (add information about archive and archive creator), but this information is corrupt or wrong. It may indicate that archive data are damaged or a corrupt or fake (illegal) rarreg.key was used to add the authenticity information.
    This particularly text got my attention...
    I have a legal bought key and never seen the authenticity error before..
    Edit: i read this in the faq section on the rar website
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    One spammer banned.... I don't think the OP will get back...
