I have a SONY CCD-TRV65 Hi8 camcorder. Tapes play with vertical jitter when TBC is turned off but plays fine with TBC turned on. However during capture, I can see pixelation near the top of the video. This occurs on all tapes. The same tapes captures fine on another SONY Hi8 camcorder and do not have vertical jitter when TBC is turned off. I have a feeling one of the electronic components like capacitor or resistor has died and this is a common problem on this model. I have attached example videos.
Just viewing in VLC on my phone at the moment, but the "pixelation" just looks like flagging that the capture device is struggling to deal with. (Which capture device?)
The general image quality would be more concerning than the flagging, to me. Such ugly sharpening artifacts. The CCD-TR818 and DCR-TRV340 I've tried add the same garbage though. EDIT mode on the CCD simply disables chroma DNR. The DNR switch only enables/disables luma DNR. Digital8 models have no EDIT switch, forcing always-on chroma DNR with some associated trailing artifacts.
I dropped off a tape to 12voltvids (YouTube) to transfer using his deck, but haven't picked it up yet. He's about 35km away and I don't head out to that area often.Last edited by Brad; 7th Jun 2017 at 09:23.
Capture device is ADVC300. Is it's DNR really that bad? I can't tell. Looks fine to me. If only someone has done / can do a side by side comparison.
I have EDIT mode OFF.
I've been watching 12voltvids videos too. He must the most popular electronic repair man on youtube? He makes it look easy repairing vintage electronics, just replace a capacitor/resistor. I even bought a Fluke 115 and ESR meter because of him.
Can you ask him what could be the problem with my Hi8 camcorder?
Do you know any other good repairman on youtube? I'm starting to watch Jordan Pier. Found a Rosie O'Kelley video, I was like O_o
Edit: Correction: The DNR is from the camcorder itself, not ADVC300 since I'm using S-video cable.Last edited by digicube; 8th Jun 2017 at 17:12.
The camcorder chroma DNR artifacts are rarely notable. The main point of my rant was that the EDIT mode can't disable the sharpening, which is the actual problem.
I could try to ask him, but you may have better luck sending him a YT msg or email.
I don't know other repair vloggers.. besides Ben Heck.
For troubleshooting, grab a blank section of tape and record to it using TRV65 (with the camcorder resting still on a surface or tripod). Play it back on the same camcorder and then other models you have and see what happens.
jitter on capture, but not on tv?
By tn-xyz in forum Capturing and VCRReplies: 21Last Post: 14th Apr 2017, 07:03 -
AVISynth: Removing Vertical Jitter
By IllusionSector in forum Newbie / General discussionsReplies: 22Last Post: 10th Feb 2017, 17:24 -
VHS jitters with TBC turned on
By timmus in forum RestorationReplies: 10Last Post: 19th Aug 2015, 11:37 -
Panasonic AG-5710 TBC - Horizontal scrolling when turned on
By mjrossit in forum Capturing and VCRReplies: 3Last Post: 22nd Jul 2014, 11:05 -
Panasonic 1980P and vertical jitter on EP playback
By justin81 in forum RestorationReplies: 10Last Post: 12th Oct 2012, 15:40
