  1. Hi, I'm a newbie and learning video encoding. I am about to encoding some dvds (two and a half men) I wonder if someone could suggest some settings.
    I did some tests and these are the results.
    CRF 20 at medium speed: 128 MiB
    Duration/String : 10 min 0 s
    OverallBitRate/String : 1 795 kb/s
    Encoded_Library_Settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    CRF 20 at slow speed: 137 MiB
    Duration/String : 10mn 0s
    OverallBitRate/String : 1910 Kbps
    Encoded_Library_Settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    CRF 19 at medium speed: 159 MiB
    OverallBitRate/String : 2222 Kbps
    Encoded_Library_Settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    I took 10 min of the same video. I just want suggestions on this, why the crf 20 slow got more mb than the medium?
  2. Originally Posted by jucasa666 View Post
    Because medium preset has smaller time allowance to improve compression further. Meaning not to encode it better but to look harder to get desired quality.
  3. And what of the three woul be the more appropriated? If you were to do the encoding?
  4. That is highly subjective, only you, by viewing it on your device, can decide what quantizer is appropriate for your video. And then how much time you can afford to encode video with slower settings (it takes a bit longer but you save some hardisk space, compare your 138MB vs 127MB using CRF 20).
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    my usual choice is CQ18 - very slow. it encodes at the quality i can live with.
  6. Mod Neophyte redwudz's Avatar
    USA
    I also use CQ18, and constant framerate with H.264/AC3 as the result. Size ~1.5GB-2.00GB.
    Looks good to me.
    canada
    I use cq 16 for dvd due to the fact that it helps to prevent moiring in black scenes.
