Complete novice here!
Starting using IP CCTV cameras and have some 1 hour long (3GB) video files. I'd like to do a simple edit, e.g. delete start and end leaving just a few minutes worth of video.
I tried AVIDemux but trying to open a file it reports - cannot find a demuxer.
Also, an attempt to open a .avi file also failed.
Searched Google and this forum but not found a solution or alternative software.
Would welcome suggestions...
Hope this is what you are asking for...
Complete name : \\QNAP212P\Public\cctv\h264 files\113-20170517-0147.h264
Format : AVC
File size : 1.58 GiB
Video
Format : AVC
Format profile : Main@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=50
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 12.500 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive -
You could try adding this to a an mkv file and see if you can open it.
Download the mkvtoolnix package and install. One of the tools is called mkvmerge.
Open it and add this file, write it out as an mkv file and see if it opens in avidemux -
Thanks for the suggestion. I downloaded mkvtoolnix and read the mkvmerge documentation. Wow! Far to complex for my tiny brain.
Fantastic. Worked a treat. Very grateful for the suggestion/instruction.
Edited file 15Mb from original 1654Mb.
Idea for programmers out there: H264 losless editing in Premiere Pr
By Tom Arrow in forum ProgrammingReplies: 0Last Post: 10th Feb 2017, 13:36 -
Most simple Handbrake setting to convert MKV to H264 or Mp4
By joms in forum Video ConversionReplies: 65Last Post: 4th Jul 2015, 02:18 -
Simple editing of iPhone videos in Windows
By Knocks in forum EditingReplies: 15Last Post: 31st Mar 2014, 19:16 -
Better alternatives to Corel VideoStudio 6 for simple editing?
By igniz12000 in forum EditingReplies: 9Last Post: 26th Nov 2013, 04:01 -
Editing Afterburner h264 AVIs? what program?
By TheFounderX in forum EditingReplies: 6Last Post: 20th Aug 2012, 21:46
