    Feb 2015
    Spain
    Hello everyone. Does anyone know how to set up this program? I put a file called mpv.config (document.txt -> mpv.config) in this direction C:\users\USERNAME\AppData\Roaming\mpv\mpv.conf and I wrote this configuration:
    volume-max=<100>
    But when I open a video file the maximum volume is at 130 not at 100.
    My intention is not to reduce the maximum volume but to learn how to configure mpv.
    Best regards
  2. Works here. Try without < and >:
    volume-max=100
    Feb 2015
    Spain
    [Attachment 41821 - Click to enlarge]
    It doesn't work either
    Has it worked for you?
    Thank you for help.
  4. File must be named "mpv.conf", not "mpv.config".
    Feb 2015
    Spain
    Now it worked. Thank you so much
