My WD NAS has two 3TB WD drives & in dashboard shows a total of 5.94TB capacity in spanning. Not sure about this figure given
the space lost by formatting. (for example my single usb 3TB HDD under my computer shows a total capacity of just 2.7TB, 300GB lost to formatting).
All my stuff on my NAS takes up 4.56TB according to rightclick-properties in windows explorer. Yet in my NAS dashboard under capacity
it all adds up to just over 5TB with 877GB free.
So how much free space would my NAS really have?
thanks
Most of the difference is in what TB means in different situations. To drive manufacturers a TB is 1000 * 1000 *1000 * 1000. To Windows a TB is 1024 *1024 * 1024 * 1024. Ie, the difference between 1,000,000,000,000 and 1,099,511,627,776.
By the way, the 2^10 (1024) byte system now uses the terms Kibi, Mebi, Gibi, Tebi, etc., abbreviated as KiB, MiB, GiB, TiB, etc.
https://en.wikipedia.org/wiki/Kibibyte
Unfortunately, Microsoft doesn't adhere to the new standard.
The conversion value depends on whether you state the size in KiB, MiB, GiB, or TiB. 1,000,000,000,000 Bytes converts to:
TiB, divide by 1.099, (1024 * 1024 * 1024 * 1024 / 1,000,000,000,000), 0.91 TiB
GiB, divide by 1.074, (1024 * 1024 * 1024 / 1,000,000,000), 931 GiB
MiB, divide by 1.049, (1024 * 1024 / 1,000,000), 953,289 MiB
KiB, divide by 1.024, (1024 / 1000), 976,562,500 KiB
Putting NAS HDD's into another same model NAS?
By Gurd99 in forum ComputerReplies: 5Last Post: 11th Jan 2017, 00:56 -
NAS vs USB HDD for Single PC setup. Reliability & ease?
By Gurd99 in forum ComputerReplies: 8Last Post: 22nd Dec 2016, 23:11 -
Does cloud storage replace or reduce server storage demand ?
By stephen1948 in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2016, 10:06 -
Only being able to acces your Data with the same HDD enclosure or NAS
By Gurd99 in forum ComputerReplies: 2Last Post: 2nd Sep 2015, 02:42 -
NAS Storage devices/Media server for live setup
By kissvid in forum ComputerReplies: 3Last Post: 16th Feb 2013, 08:35
