1.'s jpg quality is less than poor, 720 DVD image becomes 45k JPG
2.'s jpg quality is retared , 720 DVD image becomes 18k JPG
3.'s jpg quality is unacceptible , 720 DVD image becomes 13k JPG
why does the JPG quality depend on the time? this doesnt make sense to me.
what is the command that i can improve the JPG quality?
A command for JPG quality 80% ?
B command for JPG quality 85% ?
C command for JPG quality 90% ?
Default is probably a bitrate (bits per time) so if you change fps (frames per time/second) you change size of each picture.
Try instead -q:v from 2 (best) to 31 (worst). -
1. ffmpeg.exe -i %1 -r 1 -q:v 2 xxx-%06d.JPG makes 50k JPG from 720 DVD image
2. ffmpeg.exe -i %1 -r 2 -q:v 2 xxx-%06d.JPG makes 50k JPG from 720 DVD image
1. and 2. are time independant, the JPG quality is kind of good enough, but not totally keepable.
3. ffmpeg.exe -i %1 -r 1 -q:v 31 xxx-%06d.JPG makes 12k JPG from 720 DVD image
4. ffmpeg.exe -i %1 -r 2 -q:v 31 xxx-%06d.JPG makes 12k JPG from 720 DVD image
3. and 4 are time independant
question 1 : where can I find this kind of options "-q:v from 2 (best) to 31 (worst)"? because i couldnt find it anywhere in the document.
question 2: are there any reasons to use "-q:v" thing in BMP output like ffmpeg.exe -i %1 -q:v 31 xxx-%06d.BMP? because BMP is not lossy.
question 3: -q:v 1 also works but the result is the same as -q:v 2Last edited by sommers; 4th Jun 2017 at 21:35.
1. https://ffmpeg.org/ffmpeg.html#Main-options (+ Google, official ffmpeg documentation is often lacking. Worst case you have to look into the source code.)
2. That should not be the case. (But I don't know complete ffmpeg project.)
3. I assume values are clamped, i.e. any value smaller 2 is set to 2 and any value greater than 31 is set to 31. -
There is some good google search data on this subject, and I do think Ive seen where the lower the number can go is 2 or 3 on the quality scale (for JPEG image output).
I have it setup on my work computer to convert video to JPG, but the data is in google...
HTH,
Andrew
Easy265File - Preview ffmpeg command and easly convert multipe files
By gil900 in forum Video ConversionReplies: 1Last Post: 9th Jun 2017, 05:25 -
FFMPEG Same Quality Command Line
By Johnbil in forum Video ConversionReplies: 4Last Post: 7th Dec 2013, 16:06 -
ffmpeg.exe encoding mjpg at the highest quality possibile
By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 18th Nov 2013, 16:28 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53 -
problem with ffmpeg.exe
By euphonic in forum Video ConversionReplies: 4Last Post: 9th Oct 2013, 13:00
