lets say i've made a dvd rip of some anime that was in 480p format (upscaled it to 720p) in x265 format and constant quality with around 3600 kbps
if i want to apply some more changes can i apply the to the already ripped MKV file ?
i know that always its better but to save some time , would it be considered that the rip is with almost no loss of detail? (the anime is not so detailed to being with)
A lossless rip of the DVD is when you make a transfer to the HDD and the data is as it was was, no encoding or conversion has taken place.
You're talking about re-encoding an HEVC file (either in whole or part) that you made earlier from a DVD rip.
Yes, there is always some loss, but it may or may not not be noticeable during casual viewing. Results may look better or worse
depending on the material and encoder settings.
But you knew this already ... Why don't you try it and see what you can see. -
A perfect rip is an ISO file. Next is a rip of the file structure. Then a rip of the video and the audio streams, possibly concatenated and placed in a different container, but not transcoded. Turning MPEG2 into HEVC is far from lossless.
As point out earlier x265 is lossy format. upscaling to 720p does not add any new data to a 480 rip
X265 "Lossless" not really lossless and I can prove it
By sophisticles in forum Video ConversionReplies: 21Last Post: 3rd Feb 2017, 22:54 -
which time parameter to be considered in video frame for -ss flag in ffmpeg
By db2t4 in forum Newbie / General discussionsReplies: 6Last Post: 26th Oct 2016, 09:14 -
Premiere export to lossless is not lossless
By Dogway in forum EditingReplies: 66Last Post: 30th Dec 2014, 14:48 -
lossless codecs for ripped DVD-Video?
By shun in forum Video ConversionReplies: 4Last Post: 7th Jul 2014, 18:45 -
Lossless DVD compilation, best software?
By jedi55 in forum EditingReplies: 3Last Post: 1st Jun 2014, 06:10
