Results 1 to 11 of 11
  1. Anonymous
    Guest
  2. You need to install at least the driver from the software that comes with the device.
  3. Anonymous
    Guest
  4. Mod Neophyte redwudz's Avatar
    USA
    What operating system are you using?
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by hello0 View Post
    Then i connected the red, yellow and white plug to my vidorecorder, but nothing happened.
    How can this cable even detect the VHS Player?
    Your computer is not going to "detect" the VHS machine like it detects a new USB device. There is often no obvious
    sign of my USB capture device being attached to my computer until I start the capture software which forces it to
    LOOK FOR the capture device.
  6. Anonymous
    Guest
    Apr 2003
    If the manufacturer has a website you may find a more recent driver there. Or do a Google search.
  8. Does the device show up in Device Manager? Is it "unkown" or has it been properly identified and the driver installed?
  9. Anonymous
    Guest
  10. The cable shouldn't be a problem.
  11. Anonymous
    Guest
