I have some DVDs that I want to convert to MP4. There are ads I want to edit out. Should I do the editing while it's in MPEG-2 or can I convert it to MP4 first using Handbrake and then edit out the ads while in MP4 format.
What software should I use to edit out the ads? I only know of Avidemux.
Results 1 to 10 of 10
You will possibly already get rid of ad trailers if you don't try to process VOB files as they are authored on DVD, but instead extract the main movie PGC (as you always should when ripping a commercial DVD from disc). This works only with tools which are able to interpret the IFO files, like powerful DVD rippers with a Movie or IFO mode (and possibly stream processing), or PGCDemux or vStrip (when the whole content is already on the harddisk).
If trailers are still present: To cut both video and audio in sync, you could try MPEG2Schnitt or Cuttermaran. -
Editing in AviSynth is easy for the video, but recoding the audio would be a disadvantage.
MPEG-2 GOPs have a much lower complexity and diversity than MPEG-4 AVC GOPs. You can plug in an MPEG-2 Encoder as "provider" in MPEG2Schnitt as well as in Cuttermaran, so you can use e.g. HCEnc in case you need to re-encode only a cut GOP, but simply copy all the others losslessly (a.k.a. "smart rendering" in a similar context).
But as already mentioned: If you extract the main movie PGC, you will probably not even need to cut anymore. -
Thanks for the replies. It's not commercial DVDs, it's recordings off TV. I will rip the DVDs and edit the MPEG-2 first before converting it to MP4.
Old home movies now in VOB and MP4/MPEG-4 formats, want to edit and convert
By myemerald in forum Video ConversionReplies: 2Last Post: 25th Mar 2017, 15:39 -
Mp4 H.264 MPEG-4.
By OldSchool297 in forum Video ConversionReplies: 1Last Post: 17th Mar 2017, 13:03 -
Convert h.264 MP4 to DVD
By matthewjohn23 in forum Authoring (DVD)Replies: 15Last Post: 12th Jul 2014, 23:00 -
MPEG StreamClip - H.264 MP4 w/AC3 audio loses audio
By the_wallcrawler in forum Video ConversionReplies: 5Last Post: 25th Jan 2014, 03:05 -
What easier for editing: 1440x1080 MP4 or 1920x1080 AVCHD?
By Dave2ic in forum EditingReplies: 1Last Post: 25th Oct 2012, 21:37
