I see in VLC Media Player you can convert video files into 3 MP4 formats.
1. Video-H.264 + MP3 (MP4)
2. Video-H.265 + MP3 (MP4)
3. Video MPEG+2 (MP4)
Is one format a better quality than another?
Which is best?
Thank you.
Results 1 to 12 of 12
h265 is the best out of these 3 but make sure to click on "modify profile" at the right and choose a good bitrate for video and audio codecs (mp3: 192k or above and h265 i don't know but i think above 6000kbps.
you could also change mp3 for aac (better compression/rendition audio codec)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
What to you mean by best? And under what circumstances? For example, when a DVD is the source, remuxing the MPEG 2 video and AC3 audio from the DVD into an MKV container will give the best quality -- because nothing is reencoded. But the resulting file will be about the same size as the DVD. Do you have playback restrictions? h.265 currently gives the best compression -- ie the best quality at the smallest file sizes. But many devices don't play h.265 encoded video (Blu-ray players, TVs with built in media players, etc.). And it will probably take you 2 to 4 times longer to encode as h.265 (compared to h.264). Some devices (especially older Apple TVs, etc.) don't support AC3 audio in MP4.
Based strictly only your question, no. They can all be similar in quality.
There isn't a "best". It's a question of how will the file be used and which format is supported by the player.Google is your Friend -
Hi jagabo,
Do you know if h.265 will play in a TV-DVD player (think analog TV)?
Sounds like h.265 is the MP3 of video in that it sounds fine although compressed?
I was told to always save audio in .wav format (told that it was uncompressed) but listening to a song in .wav and then in .mp3 I can't detect any sound quality difference.
I don't own a $100k+ stereo sound system so maybe if I did then I would notice the difference?
But. mp3 songs are about 1/3 the size of a .wav song so if I can't hear the difference then why save a music file as .wav?
Hi the masterone,
Which program do you use to "modify profile"?
I was looking at VLC Media Player to convert the .webm into a mp4 as an experiment.
Thanks so much.
DVD Player? Not even a Blu-ray player? Extremely unlikely. These are mostly MPEG family codecs, in order of increasing complexity:
Each generation offers about a 2x increase in compression. Only devices made in the last few years are going to have the ability to play h.265.Code:MPEG 1 (VCD) MPEG 2 (DVD) MPEG 4 part 2 (XVID, DIVX) MPEG 4 part 10 (h.264, AVC, Blu-ray) MPEG H part 2, (h.265, HEVC, Ultra HD 4K Blu-ray )
already answered, only recent tv's built in the last 2-3 years.
the 2nd best for you would be H264 (more compatible) but with a higher bitrate (9000 kbps) most likely (i haven't tested vlc codecs that much to be sure)
wav is fine if you're picky or for archival purposes or post production editing.
the mp3 codec like the other audio codec cut high/low frequencies that humans can't hear but take mp3 for example a bitrate of 320 kbps will keep these frequencies (= great fidelity), below not.
And for aac i don't know precisely but probably half this bitrate ( = file size smaller+ great fidelity)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
265 is better for 2.5k/UHD/Etc resolution.
Up to 1080, maybe even fine for 2.5K, H264 is plenty good, and its what I still use (H264 & AAC for MP4 container). It also helps to keep a device from puking when I try to play (265 is still "new").
MPEG2 looks good, but... you need "twice" the bitrate at 1080 for it to look good. Hell, XviD looks great at 1080 and 12mbps! <grin>
EB
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 11:27 -
Chinese video formats
By Losthost in forum Video ConversionReplies: 0Last Post: 26th Jan 2017, 03:30 -
Help- editing different video formats
By MadiraNofo in forum EditingReplies: 7Last Post: 11th Sep 2016, 12:43 -
Old Video Formats Help
By Velhans in forum Video ConversionReplies: 8Last Post: 28th Jun 2015, 21:29 -
Video formats for USB and SD cards ?
By freevideo in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2013, 12:14
