I posted some question on videolan, but noone seems to know the answers, I am sure you do better. I repeat them below.
I am getting the message: VLC Stream Input Cannot be Opened.
Is this because the URL is https? If so, is there a solution?
I also note that the MRL is https://www........
Surely it should be URL, URI?
I use online tv (streamed), but have buffering problems.
Someone suggested using vlc to avoid the browser problems.
I pasted a video stream into vlc, under streaming, and received errors (above).
Can someone tell me what I am doing wrong. Is it the https?
Generally, when I am streaming will the stream be stored somewhere on my pc. I have limited space and will need to delete them
What are the streaming formats?
I note that on some videos the sound is out of sync with the video, and the video is a bit jerky. Why is this?
	Just a thought as I've not used VLC in this fashion, but depending on the source and stream type, the stream could use some sort of DRM which the browser can handle and VLC doesn't support.
 Unlike back in the day, I don't believe most current streaming types are stored. The data is buffered and removed as it plays or when the player is closed.Google is your Friend
	Thanks for responding
 The streams are from public sites. I wonder if DRM would be involved
 Would https cause a problem?
 s
 Any thoughts regarding the lack of sync between sound and video. This problem occur only on some videos and is not a general phenomenon.
 MRL and not URL surprised me.
 I am wondering what formats are used by the streams?
 Best wishes
 Ps. I wonder why some people stream files that are stored on their pc. why not just open them in a player. In this case, I am asking what is the difference between streaming a file and simply opening it in a player; VLC, for example, can do both.Last edited by anon_private; 2nd Jun 2017 at 17:26.
	Streaming implies playing the file from a different location or playing a file and streaming it to another destination.
 VLC streaming, for example, you can play a file and stream it across your LAN and anyone else on the LAN can watch what you are watching. Another example would be Plex, where you can connect to your PC from another device and stream any content stored on the computer to that device.
 Or in general terms. You play locally, you stream to another device.Google is your Friend
  Unable to convert video with VLC.By Roméo Latour in forum Video ConversionReplies: 12Last Post: 15th Apr 2015, 11:37
  MP4 Playback No Video VLCBy gstone in forum Software PlayingReplies: 3Last Post: 28th Jan 2014, 17:27
  VLC:How can I add new/outer fitler or decoders to VLC?By dayangwc in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2013, 07:33
  Problem with video in VLCBy ROBO731 in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2012, 16:25
  Video goes WIDESCREEN After A Few Seconds In VLCBy hech54 in forum EditingReplies: 5Last Post: 28th Jun 2012, 11:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
