I have WinXP Pro, Geforce 2 mx 200 w/tvout, and TV Wonder PCI. I installed the XP drivers from ATI and everything works fine except for the fact that when I capture I have a horizontal line at the bottom of the movie(file) that is out of sync.....anyone have any similar probs? I tested it with 2 different inputs to ensure that it wasn't that.....I am using the composite in... I tried in MMC 7.1 and Adobe Premeire 6.0 but the same results....Do you think that it's just a bad card?
I also tried using PowerVcR II. Same horizontal bar.....just 3 or 4 bars from the bottom.....It even does it when I capture a still....
Unfortunately, that's because of composite in or VHS, I'm not sure which, but it's the same with all tuners. If you can set your capture program to overscan, you'll be fine, if not, you'll need cropping.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 17:01
