i got an mp4 which says the audio is disabled. Here is the mediainfo. Can the audio be enabled?
________________
General
Complete name : C:\Users\sounds\film.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 29.6 MiB
Duration : 11 min 7 s
Overall bit rate : 373 kb/s
Writing application : Lavf57.11.100
Video
Format : AVC
Format profile : Main@L1.3
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Bit rate : 243 kb/s
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.126
Stream size : 19.3 MiB (65%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate mode : Constant
Bit rate : 125 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Stream size : 9.98 MiB (34%)
Default : Yes
Alternate group : 1
Results 1 to 13 of 13
Try:
ffmpeg -i "C:\Users\sounds\film.mp4" -map 0 -c copy "C:\Users\sounds\film_enabled.mp4" -
It worked on a sample I tested. You said "i got an mp4 which says the audio is disabled" but which program is showing you exactly what error message? Sample file?
Maybe the person meant that the audio was disabled during recording or production ? ie. it's blank audio . In that case, you can't "enable" it because it's silent audio
Check with the person -
Yes, VLC respects the disabled flag. For me the command in #2 works.
Looking again at the MediaInfo log it says "Default : Yes" which I believe is MediaInfo's way of showing the disabled flag's absence in mp4 container. So there should be nothing to change. Maybe the person testing is just confusing different files. Or like poisondeathray said. -
Extract the audio from the MP4 file as a separated audio track and examine it in an audio editor like Audacity etc. It might be a silent track...
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thanks sneaker, I learned something... now I need to google the flags, its something I have yet to encounter.
Thanks!
Andrew
No Sound in Mp4 video editing (but sound in playback)
By Brianhockey12 in forum AudioReplies: 2Last Post: 15th Mar 2017, 11:13 -
[Solved] MP4 No Sound [bad record without sound]
By gallatatv in forum Software PlayingReplies: 5Last Post: 4th Jan 2016, 18:30 -
Sound broken mp4
By correx in forum Software PlayingReplies: 8Last Post: 7th Oct 2014, 04:20 -
DVDFab No Sound when creating MP4. Change extension to M4V and sound works
By hackerjunk in forum DVD RippingReplies: 2Last Post: 5th Jun 2014, 15:04 -
5.1 Sound in MP4
By encodingmonkey in forum Video ConversionReplies: 0Last Post: 14th Aug 2013, 14:14
