Hello guys!
Where can I find the forum and homepage of Lav Filters? I would like to report some bugs.
Thank you for your reply!
Results 1 to 9 of 9
AnonymousGuest
Thread @ doom9.org:
https://forum.doom9.org/showthread.php?t=156191
Page @ GitHub:
https://github.com/Nevcairiel/LAVFilters/issues -
AFAIK the correct place is the Doom9 forum which you access as 'Visit Developer's site' from the generated link on your OP
I didn't get the promised registration e-mail... I tried it again with an other address and account name...but the result was the same... no e-mail. The style of that webpage reminds me of the early 2000s... Maybe they use stone-age servers too...
This is the Changelog of LAV Filters:
Version history / Release notes / Changelog
"0.70.0 - 2017/xx/xx
LAV Splitter
- Fixed: Certain MP4/MOV didn't play or seek correctly in recent versions of LAV Splitter
- Fixed: HEVC in MP4 without PTS timestamp is being signaled appropriately"
__________________________________________________ __
But they forget to refit this exact problem in MPEG transport stream (MPEG-TS, MTS or TS)
Can somebody write to fix it in their forum?
Thank you for your reply!Last edited by Stears555; 1st Jun 2017 at 13:39.
Did you try the latest nightly? Do you have a sample? A report without a sample is useless. Or better yet just report via github if you can't get registered on doom9.
Here is the sample: http://sendgb.com/KVIAnhCEi7P The plot: Three common wall lizards try to eat an earth-worm.
The video is a progressive Segmented Frame video, so please turn of the deinterlacer or automatic deinterlacer, because it can half the spatial resolution, thus degrading the video. I use Potplayer, and I set my mouse scroll to frame step back or forward. When I use the LAv Filters decoder and LaV splitter the frame-step (especially back) doesn't work really. But they solved this problem with Mp4 and MKV format, as their changelog wrote. So when I transform the video into mp4 or mkv, the problem doesn't exist anymore, it is fine. That's why I said, they must take a look to the transport stream formats, because the problem remained there. It is especially more problematic in really long videos. I uploaded only a very small sample. -
The changelog says some (not further specified) playback and seeking problems in mp4 were fixed, not necessarily a problem like you are describing. IIRC it was about reordering not having been saved correctly (missing CTTS atom). I don't really see any relation to your problem not least because it only affected HEVC while your sample is AVC.
Some time ago LAV author said:
https://forum.doom9.org/showthread.php?p=1803567#post1803567MPEG-TS is generally not a format you should expect "perfect" seeking on, because the format itself has basically no seeking support. Even finding the appropriate timecode in the file is already a slow process, and with broadcast streams can even be really annoying (ie. with wrap-around). -
Hello!
I mean this line:
"- Fixed: Certain MP4/MOV didn't play or seek correctly in recent versions of LAV Splitter"
Many other decoders have not such a problems with the Transport streams, but LAV filters have. I clearly remember old LAV filters have worked great with Transport streams even 1 or 2 years ago, so it means, there is a problem with the newer versions. Interestingly, when I transformed them to mkv or mp4 with direct-stream-copy mode, the problem has disappeared. Isn't it interesting? LAV filters works a bit better with other splitters. That's why I said, there is a problem with the LAV splitter.
Installed Codecs and LAV Filters
By Nitobert in forum Video ConversionReplies: 4Last Post: 30th Jan 2017, 04:29 -
Dates of LAV filters
By jgg in forum Software PlayingReplies: 6Last Post: 27th Jan 2016, 14:02 -
Help with Potplayer with LAV Filters + receiver?
By Fabulist in forum AudioReplies: 2Last Post: 22nd Oct 2015, 03:06 -
Do I need LAV filters?
By Yanta in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2015, 04:01 -
Embed subtitles with lav filters?
By dude112 in forum Video ConversionReplies: 3Last Post: 22nd Sep 2013, 08:33
