Hello experts.
I have reeeeally huge problem that is driving me crazy.
I always exported videos with my elgato hd 60 and I never had problems. The only one thing was that it was really slow in the postprocessing. So I found a video in which there was explained how to avoid this time. Anyway that wasn't good for me. After that I made a moving, so I plugged all the cables out and then again in. Now I have the problem that my exported videos are in really bad quality compared to the previous ones. If I check the videos in my folder "Videos" the quality is really bad, if I check them in the "edit" of elgato software they are good as previous ones (and also in 60fps, despite the ones in "videos" folder). How can I have my high wuality videos back? In the elgato the videos are really good, but the exported ones are really bad. I attach the images of my settings.
[Attachment 41776 - Click to enlarge]
[Attachment 41777 - Click to enlarge]
[Attachment 41778 - Click to enlarge]
[Attachment 41779 - Click to enlarge]
	Uninstall and reinstall the software to try to get the settings back at default?
 Why do you need to export in the Elgato software anyway?If I check the videos in my folder "Videos" the quality is really bad, if I check them in the "edit" of elgato software they are good as previous ones (and also in 60fps, despite the ones in "videos" folder). How can I have my high wuality videos back? In the elgato the videos are really good, but the exported ones are really bad. I attach the images of my settings.
  Elgato HD60 Divides Recorded FilesBy yaston in forum Capturing and VCRReplies: 21Last Post: 23rd Feb 2016, 19:01
  Elgato HD60 HelpBy ashly1990 in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2016, 04:44
  Elgato HD60 video corruption problemBy akaranzo in forum Capturing and VCRReplies: 0Last Post: 15th Nov 2015, 06:44
  Streaming problem with ELGATO HD60By yaston in forum Video Streaming DownloadingReplies: 18Last Post: 14th Nov 2015, 13:43
  Elgato Game Capture HD60 ProblemBy yaston in forum Capturing and VCRReplies: 1Last Post: 12th Nov 2015, 15:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
