I'm using the Avidemux program to edit video clips.
I'm wondering if anyone knows if there is a way to save certain output settings on the left bar so that they are always the same when you open the program and edit?
I need certain output settings and it is annoying to have to set them each time.
This is what I need:
It would be good to have these outputtings as default without needing to select them each time.
Thanks for any help.
