Ok im a noobie just bought this app for the group file converter. If i complete one file editing it I can't go to the next file in the group file button because its disable. Help
TexG
Results 1 to 12 of 12
I have notice that if i select a audio or a video track and then edit the title info like the name of the video or the audio change to english. Ether one if selected (check box) then you press enter the conversation starts. Don't like that would like more control over when it start and when i go throw the group list. I to program and one of the biggest thing i have to do is always second guess the users actions. This is a good program, BUT it could be greater with a little more direction on how it reacts to the users actions. you have all the functions there. Just need the other. Just food for thought. Would like to know if there is work around for my first comment.
TexG -
MKVToolNix is a free tool. if you have used something else that uses almost the same name, too bad you've been scammed.
aedipuss: The OP isn't referring to MKVtoolnix, but the shareware/payware app MKVTools, for the Mac, I believe.
If cameras add ten pounds, why would people want to eat them? -
Ok confused. Is it he thinks I'm using mkvtoolnix. Mine not I'm using mkvtools.
TexG -
Considering the majority of members here use Windows, most likely no one has used that app.
Google is your Friend -
Better asked and answered in our Mac Forum. Moving it.
Moderator redwudz -
One of the differences between the paid version and the trialware, is the batch function. Did you register it and enter the registration code, to unlock the batch functionality?
The developer was a member here, but hasn’t visited since 2012. If you have suggestions regarding the software, then you should contact him directly.
I’m pretty sure EmmGunn is a one person operation for the software part, although that is not really important here. I did use his tools long ago, when I was tinkering with AVI files. If you bought registration through his website, then I see no reason for such negative thoughts.
Added 1 extra Audio/Subtitle file to a DVD, VIDEO_TS = OK ,ISO=NOT
By DeusExMachinaN7 in forum Authoring (DVD)Replies: 7Last Post: 10th Oct 2016, 04:14 -
MKVTOOLS says 'Completed' but no output file
By hmgnsd in forum MacReplies: 3Last Post: 28th Aug 2016, 05:04 -
MKVToolNix GUI - Added chaprter in mkv file not work on BD player. Why?
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 1Last Post: 23rd Jun 2016, 00:24 -
MKVToolNix GUI - Splitting a file with multiple file parts added to it
By MisterNewb in forum EditingReplies: 5Last Post: 13th Sep 2015, 11:47 -
Problem with MKVTools 3.0
By xalodogan in forum MacReplies: 2Last Post: 1st Jun 2012, 13:25
