Hello everybody!
I need help. I have Bluray movie. In the STREAM folder i have more m2ts files. How to join this m2ts files and create one big file? But this one big m2ts file must be made so that i can choose subtitles from Bluray MENU and that will give play. I have MultiAVCHD and tsmuxerGui, but i do not know how to do it.
Pleace help me.
Best regards
	@pepegot1
 Thx for reply, but you not understand me. This movie have Menu, problem are in m2ts files, because inside STREAM folder its more m2ts file. I want to bring together these small m2ts files in one big m2ts file and after that i must replace old files with new cretaed file, then when i go to MENU and choice PLAY, movie must be started from the MENU!
	Should there be a m2TS file containing the main title of the Blu-ray movie? Other m2ts might be the extras.
	Main movie can be split into many m2ts files. An mlps contains/ is the actual playlist.
 [Attachment 41838 - Click to enlarge]
 That movie have a playlist like i write on last.Last edited by malimuc; 8th Jun 2017 at 09:34.
  Create Bluray (MKV->Bluray) with custom menuBy ThaDraGun in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Aug 2015, 20:52
  Replacing multiple M2TS files with one large M2TS - possible??By kpic in forum Authoring (Blu-ray)Replies: 0Last Post: 1st Nov 2014, 01:55
  Merge BluRay playlist to single m2ts?By Numinel in forum Authoring (Blu-ray)Replies: 4Last Post: 6th Jun 2014, 02:01
  Is there a simple way to reassign an audio track in a m2ts from a bluray?By yoda313 in forum Video ConversionReplies: 0Last Post: 6th Apr 2013, 00:36
  Adding new M2TS file to existing bluray with menus intactBy tanzer26 in forum Authoring (Blu-ray)Replies: 6Last Post: 25th Jun 2012, 08:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
